Discuss
Kenmore Elite Dryer E1 error message
 in
Dryer Repair
The dryer keeps shutting off and the E1 error message appears. It seems to heat fine, but not sure why
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Kenmore Elite Dryer E1 error message
  #1 (permalink)
Old 07-03-2009, 03:09 PM
srtroy srtroy is offline
Junior Member
srtroy is on a distinguished road
Default Kenmore Elite Dryer E1 error message
Model Number: 110.82822181   Brand: Kenmore   Age: 5 - 10 years
The dryer keeps shutting off and the E1 error message appears. It seems to heat fine, but not sure why it is doing this.
What does the message refer to, and how do you fix the problem?
Related Models
Kenmore 110.82824100  ELECTRIC DRYER
Kenmore 110.82824101  ELECTRIC DRYER
Kenmore 110.82824102  ELECTRIC DRYER
Kenmore 110.82826100  ELECTRIC DRYER
Kenmore 110.82826101  ELECTRIC DRYER
Kenmore 110.82826102  ELECTRIC DRYER
Kenmore 110.82832100  DRYER
Kenmore 110.82834100  DRYER
Kenmore 110.82836100  DRYER
Kenmore 110.83679630  ELECTRIC DRYER
Kenmore 110.84832200  ELECTRIC DRYER
Kenmore 110.84832201  ELECTRIC DRYER
Kenmore 110.84834200  ELECTRIC DRYER
Kenmore 110.84834201  ELECTRIC DRYER
Kenmore 110.84836200  ELECTRIC DRYER
Kenmore 110.84836201  ELECTRIC DRYER
Kenmore 110.86015100  ELECTRIC DRYER
Kenmore 110.86015110  ELECTRIC DRYER
Kenmore 110.86015120  ELECTRIC DRYER
Kenmore 110.86030100  ELECTRIC DRYER
Kenmore 110.86030110  ELECTRIC DRYER
Kenmore 110.86030120  ELECTRIC DRYER
Kenmore 110.86070100  ELECTRIC DRYER
Kenmore 110.86070110  ELECTRIC DRYER
Kenmore 110.86405160  COMMERCIAL ELECTRIC DRYER
Kenmore 110.86405860  COMMERCIAL ELECTRIC DRYER
Kenmore 110.86407140  ELECTRIC DRYER
Kenmore 110.86407160  COMMERCIAL ELECTRIC DRYER
Kenmore 110.86407840  ELECTRIC DRYER
Kenmore 110.86407860  COMMERCIAL ELECTRIC DRYER
Kenmore 110.87405140  GAS DRYER
Kenmore 110.87405160  COMMERCIAL GAS DRYER
Kenmore 110.87405840  GAS DRYER
Kenmore 110.87405860  COMMERCIAL GAS DRYER
Kenmore 110.87407140  GAS DRYER
Kenmore 110.87407840  GAS DRYER
Kenmore 110.92490100  GAS DRYER
Kenmore 110.92822100  GAS DRYER
Kenmore 110.92822101  GAS DRYER
Kenmore 110.92822102  GAS DRYER
Kenmore 110.92824100  GAS DRYER
Kenmore 110.92824101  GAS DRYER
Kenmore 110.92824102  GAS DRYER
Kenmore 110.92826100  GAS DRYER
Kenmore 110.92826101  GAS DRYER
Kenmore 110.92826102  GAS DRYER
Kenmore 110.92832100  DRYER
Kenmore 110.92834100  DRYER
Kenmore 110.92836100  DRYER
Kenmore 110.94832200  GAS DRYER
Kenmore 110.94832201  GAS DRYER
Kenmore 110.94834200  GAS DRYER
Kenmore 110.94834201  GAS DRYER
Kenmore 110.94836200  GAS DRYER
Kenmore 110.94836201  GAS DRYER
Kenmore 110.96060100  ELECTRIC DRYER
Kenmore 110.96091100  ELECTRIC DRYER
Kenmore 110.96091300  ELECTRIC DRYER
Kenmore 110.96091700  ELECTRIC DRYER
Kenmore 110.96091800  ELECTRIC DRYER
Kenmore 110.96093100  ELECTRIC DRYER
Kenmore 110.96093300  ELECTRIC DRYER
Kenmore 110.96093500  ELECTRIC DRYER
Kenmore 110.96093700  ELECTRIC DRYER
Kenmore 110.96093800  ELECTRIC DRYER
Kenmore 110.96094100  ELECTRIC DRYER
Kenmore 110.96094300  ELECTRIC DRYER
Kenmore 110.96094500  ELECTRIC DRYER
Kenmore 110.96094700  ELECTRIC DRYER
Kenmore 110.96094800  ELECTRIC DRYER
Kenmore 110.96110100  ELECTRIC DRYER
Kenmore 110.96121100  ELECTRIC DRYER
Kenmore 110.96195100  ELECTRIC DRYER
Kenmore 110.96195110  DRYER FEATURE SHEET
Kenmore 110.96407160  COMMERCIAL ELECTRIC DRYER
Kenmore 110.97502120  GAS DRYER-COMMERCIAL
Kenmore 110.97502820  GAS DRYER-COMMERCIAL
Kenmore 110.97565120  GAS DRYER
Kenmore 110.97565220  GAS DRYER
Hoover 1100
Magic Chef 1100PAA Range - F/s Std Gas
Magic Chef 1100PAW Range - F/s Std Gas
Magic Chef 1100PAW-K Range - F/s Std Gas
Magic Chef 1100PAW-KL Range - F/s Std Gas
Magic Chef 1100PAW-L Range - F/s Std Gas
Magic Chef 1100PRA Range - F/s Std Gas
Magic Chef 1100PRA-K Range - F/s Std Gas
Magic Chef 1100PRW Range - F/s Std Gas
Magic Chef 1100PRW-K Range - F/s Std Gas
Kenmore 11014202300 AUTOMATIC WASHER
Kenmore 11014222300 AUTOMATIC WASHER
Sears 11016502693 AUTOMATIC WASHER
Sears 11016502694 AUTOMATIC WASHER
Sears 11016512691 AUTOMATIC WASHER
Sears 11016512692 AUTOMATIC WASHER
Sears 11016602690 AUTOMATIC WASHER
Sears 11016602691 AUTOMATIC WASHER
Sears 11016602692 AUTOMATIC WASHER
Sears 11016602693 AUTOMATIC WASHER
Sears 11016611690 AUTOMATIC WASHER
Sears 11016611691 AUTOMATIC WASHER
Sears 11016611692 AUTOMATIC WASHER
Sears 11016612690 AUTOMATIC WASHER
Sears 11016612691 AUTOMATIC WASHER
Sears 11016612692 AUTOMATIC WASHER
Sears 11016872691 AUTOMATIC WASHER
Sears 11016872692 AUTOMATIC WASHER
Sears 11016872693 AUTOMATIC WASHER
Sears 11018542890 AUTOMATIC WASHER
Hoover 1102
Kenmore 11020052994 WASHER
Kenmore 11020056991 WASHER
Kenmore 11020056992 WASHER
Kenmore 11020056994 WASHER
Kenmore 11020072990 WASHER
Kenmore 11020072991 WASHER
Kenmore 11020072992 WASHER
Kenmore 11020072993 WASHER
Kenmore 11020092990 WASHER
Kenmore 11020092991 WASHER
  #2 (permalink)
Old 07-04-2009, 07:40 AM
sidfink43 sidfink43 is offline
Senior Expert
APP Volunteer
sidfink43 is on a distinguished road
Default
Hi Srtroy
I cannot get your model number to come up, but in general the error message you are getting is usually associated with a bad thermistor.
A thermistor is an electric device whose resistence changes as the termparature changes. In your dryer it is sited in the exhaust air vent and monitors the temperature of the exhaust air. This allows it to help control the thermostat so that your dryer runs at the correct temperature. When it goes bad you get the E1 error.
Here's what I would recommend. First take off the bottom panel and you should find some tech notes and trouble shooting info. Go through any troubleshooting routine and confirm the E1 error is associated with the thermistor. The tech notes will probably have a way to test the thermistor if you want to confirm a diagnosis.
If it is the thermistor, remove the vent cover and replace it. It comes off with two screws so it is a pretty easy job.
Good luck, let us know what you find out.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore Elite HE3 Electric Washer F-DL Error BerkelUSA Washer Repair 3 07-20-2009 10:00 AM
Kenmore Elite Range error code help jayp Oven Repair (including Ranges and Cooktops) 15 07-08-2009 03:27 PM
kenmore elite he3 -- F 05 error??? deannahoffmann Washer Repair 1 02-26-2009 06:46 AM
Kenmore Elite Electric Range F20 Error davco Oven Repair (including Ranges and Cooktops) 1 03-18-2008 07:42 PM
Kenmore Elite range F501 error paulgoh Oven Repair (including Ranges and Cooktops) 7 02-14-2008 01:46 PM
