| » Heat but No tumble; belt is not broken |
Hard to be accurate without a model number, but possibly a blown thermal fuse. If the machine got hot enough to blow this fuse, you may also have an open thermostat. If replacing thermal fuse and/or thermostat, it's recommended that you go ahead and replace them all at the same time. Check the vent system for restriction or obstruction: this is one of the most common causes of overheating.
| Display Modes | |
| Whirlpool dryer will not tumble. Belt issue? | marc127 | Dryer Repair | 3 | 08-31-2009 03:18 PM |
| how to replace belt for tumble dryer | wendy poulton | Dryer Repair | 2 | 11-18-2008 10:43 AM |
| Gas dryer...tumble, no heat, igniter OK | spark3542 | Dryer Repair | 13 | 10-03-2008 11:14 AM |
| broken belt | mpsals1111 | Dryer Repair | 1 | 07-20-2008 02:44 AM |
| Broken belt | Carlos | Washer Repair | 3 | 03-13-2008 06:28 PM |
