Appliance Repair Forum
-   Dryer Repair (http://forum.appliancepartspros.com/dryer-repair/)
-   -   Heat but No tumble; belt is not broken (http://forum.appliancepartspros.com/dryer-repair/39114-heat-but-no-tumble-belt-not-broken.html)
LWJ 07-01-2009 01:44 PM
My dryer stopped working. The heat comes on but it won't tumble. I had a handyman look at the belt and he said it was still on and not broken. The night before it stopped working, I noticed the dryer itself was extremly hot. I bought this dryer new 8 months ago. I have a repairman coming but not for another week. Any advice would be appreciated. Thanks!
magician59 07-01-2009 02:28 PM
Hard to be accurate without a model number, but possibly a blown thermal fuse. If the machine got hot enough to blow this fuse, you may also have an open thermostat. If replacing thermal fuse and/or thermostat, it's recommended that you go ahead and replace them all at the same time. Check the vent system for restriction or obstruction: this is one of the most common causes of overheating.
richappy 07-01-2009 02:34 PM
I would look for a shorted heater coil to the housing.
LWJ 07-01-2009 03:00 PM
Model # is WED5300SQ0
