dbrown1@ctc.net
#1 Posted : Thursday, December 22, 2011 5:07:14 PM(UTC)
dbrown1@ctc.net
Frigidaire Dryer does not heat on any selection.After cycle has been on a code E4A will display(cycle over run).Help
d brown
#2 Posted : Friday, December 23, 2011 3:40:09 AM(UTC)
Replacement parts for AEQ7000EGO models | AppliancePartsPros.com
Here is the tech sheet
http://manuals.frigidaire.com/p...r/134682200ts_wd_EFS.pdf
And here is a manual
Frigidaire Affinity Dryer Service Manual - ApplianceDigest.com
You have to join the site to download the manual but it is free and this is a very good site for manuals and other info for the appliance repair DIYer.
Error points toward your no heat problem.
I would start by checking the power, the heating coil needs the full 240 volts everything else runs off of half the line (120).
Try flipping the breaker off/on slowly a couple times.
Sometimes you can loose half the line without actually tripping the breaker.
If this does nothing, check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
If OK
Unplug the unit and ones side of the heating coil and check it with a meter, should be around 12 ohms.
If OK
Check the hi-limit thermostat, should be 0 ohms.
If this is open get back to us as there are other things that should be checked before replacing it.
PIXZAN
#3 Posted : Monday, December 26, 2011 1:13:02 PM(UTC)
PIXZAN
CAN SOMEONE TELL US HOW TO DISASSEMBLE THE DRYER SO WE CAN REMOVE THE DRUM IN ORDER TO REPLACE THE HEATING ELEMENT? WE BROUGHT THE PART, MY HUSBAND AND SONS TRIED TO TAKE IT APART AND COULDN'T REMOVE THE DRUM. NOW THEY WANT TO TRASH IT. I HAVE TRIED SEARCHING YOU TUBE AND THE INTERNET FOR A VIDEO OF HOW TO OPEN UP THE DRYER FOR ACCESS BUT COULD NOT FIND ANYTHING SIMILAR. DOES ANYONE KNOW OF A VIDEO SHOWING HOW TO DISASSEMBLE THE DRYER?? (found the washer....)
Thank you.
Control board for Frigidaire Affinity dryer (E68 error code) (Appliance Parts)
by VanFramez 12/18/2022 11:57:30 AM(UTC)
Frigidaire Affinity Dryer, seem stuck on high heat (Dryer Repair)
by GoldToyBox 4/29/2022 4:53:20 PM(UTC)
frigidaire affinity dryer LEQ6000es2 Stuck in mode (Dryer Repair)
by Guest 7/13/2021 5:25:53 AM(UTC)
2011 Frigidaire Affinity Dryer (Dryer Repair)
by Donnchad 11/1/2020 3:01:12 PM(UTC)
Frigidaire affinity dryer model number fase7073a2 (Dishwasher Repair)
by Ann P 7/28/2020 7:31:25 PM(UTC)
Frigidaire Affinity Dryer AGQ6700FS2 (Dryer Repair)
by moh 7/8/2020 3:29:08 PM(UTC)
On startup Frigidaire Affinity Dryer Whirs, clunks, and then is fine (Dryer Repair)
by RPD15 4/24/2017 6:15:38 PM(UTC)
Frigidaire Affinity dryer: Won't stop beeping. (Dryer Repair)
by jt_app 5/21/2016 9:46:46 AM(UTC)
E68 Error Code - Frigidaire Affinity Dryer (Dryer Repair)
by davidrcarlson 6/13/2014 4:25:37 AM(UTC)
frigidaire affinity dryer working, no heat (Dryer Repair)
by reverendalc 6/29/2013 3:28:39 PM(UTC)
Frigidaire affinity dryer overheating (Dryer Repair)
by Cwalker 5/24/2013 7:50:16 PM(UTC)
Frigidaire Affinity dryer power (Dryer Repair)
by MGibellino 12/6/2012 5:36:30 PM(UTC)
Frigidaire Affinity dryer error code E61 (Dryer Repair)
by napclan6 2/11/2012 12:33:13 PM(UTC)
Frigidaire Affinity Dryer AEQB7000ES0 Error Code E56 (Dryer Repair)
by dignan 2/3/2012 12:40:03 PM(UTC)
Frigidaire Affinity dryer making weird noise (Dryer Repair)
by loulou77 11/4/2011 4:17:44 PM(UTC)
