Discuss
Dryer won't stay powered on
 in
Dryer Repair
Maytag Neptune dryper won't stay powered up after the power switch is pushed. It will however stay on after
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Dryer won't stay powered on
  #1 (permalink)
Old 07-19-2007, 07:12 PM
karlkauai karlkauai is offline
Junior Member
karlkauai is on a distinguished road
Default Dryer won't stay powered on
Model Number: MDG5500AWW   Brand: Maytag   Age: 1 - 5 years
Maytag Neptune dryper won't stay powered up after the power switch is pushed. It will however stay on after several times. Sounds like a relay in the left side of machine won't stay energized. Get's Error code PF, if you push the switch only once. What is the problem and what parts do I need to fix it.
Thanks,
Karl B Frederick
Related Models
Maytag MDG5500AWW Dryer - Gas
Maytag MDG5806AWK Dryer - Gas
Maytag MDG5806AWW Dryer - Gas
Maytag MDG5960BWW Dryer - Gas
Maytag MDG6000AWQ Dryer - Gas
Maytag MDG6000AWW Dryer - Gas
Maytag MDG6000AXW Dryer - Gas
Maytag MDG6000BWQ Dryer - Gas
Maytag MDG6000BWW Dryer - Gas
Maytag MDG6200AWQ Dryer - Gas
Maytag MDG6200AWW Dryer - Gas
Maytag MDG6400AWQ Dryer - Gas
Maytag MDG6400AWW Dryer - Gas
Maytag MDG6460AWW Dryer - Gas
Maytag MDG6657BWQ Dryer - Gas
Maytag MDG6657BWW Dryer - Gas
Maytag MDG6700AWM Dryer - Gas
Maytag MDG6700AWW Dryer - Gas
Maytag MDG6800AWB Dryer - Gas
Maytag MDG6800AWQ Dryer - Gas
Maytag MDG6800AWW Dryer - Gas
Maytag MDG7057AWQ Dryer - Gas
Maytag MDG7057AWW Dryer - Gas
Maytag MDG7057BWQ Dryer - Gas
Maytag MDG7057BWW Dryer - Gas
Maytag MDG7400AWQ Dryer - Gas
Maytag MDG7400AWW Dryer - Gas
Maytag MDG7460AWQ Dryer - Gas
Maytag MDG7460AWW Dryer - Gas
Maytag MDG7500AWQ Dryer - Gas
Maytag MDG7500AWW Dryer - Gas
Maytag MDG75MNAWW Dryer - Gas
Maytag MDG75MNVWQ Dryer - Gas
Maytag MDG75MNVWW Dryer - Gas
Maytag MDG75PN1AW Dryer - Gas
Maytag MDG75PN2VW Dryer - Gas
Maytag MDG75PNAVW Dryer - Gas
Maytag MDG75PNHWQ Dryer - Gas
Maytag MDG75PNHWW Dryer - Gas
Maytag MDG75PNVVQ Dryer - Gas
Maytag MDG75PNVVW Dryer - Gas
Maytag MDG75PNVWQ Dryer - Gas
Maytag MDG75PNVWW Dryer - Gas
Maytag MDG7600AWQ Dryer - Gas
Maytag MDG7600AWW Dryer - Gas
Maytag MDG7657AWQ Dryer - Gas
Maytag MDG7657AWW Dryer - Gas
Maytag MDG7657BWQ Dryer - Gas
Maytag MDG7657BWW Dryer - Gas
Maytag MDG7658AWQ Dryer - Gas
Maytag MDG7658AWW Dryer - Gas
Maytag MDG7658BWQ Dryer - Gas
Maytag MDG7658BWW Dryer - Gas
Maytag MDG76PCBWS Dryer - Gas
Maytag MDG76PCBWW Dryer - Gas
Maytag MDG7757AWQ Dryer - Gas
Maytag MDG7757AWW Dryer - Gas
Maytag MDG7758AWQ Dryer - Gas
Maytag MDG7758AWW Dryer - Gas
Maytag MDG77PNAWW Dryer - Gas
Maytag MDG77PNSWW Dryer - Gas
Maytag MDG8000AWQ Dryer - Gas
Maytag MDG8000AWW Dryer - Gas
Maytag MDG8000BWQ Dryer - Gas
Maytag MDG8000BWW Dryer - Gas
Maytag MDG8057AWQ Dryer - Gas
Maytag MDG8057AWW Dryer - Gas
Maytag MDG8057BWQ Dryer - Gas
Maytag MDG8057BWW Dryer - Gas
Maytag MDG8058BWQ Dryer - Gas
Maytag MDG8058BWW Dryer - Gas
Maytag MDG8400AWQ Dryer - Gas
Maytag MDG8400AWW Dryer - Gas
Maytag MDG8416AWA Dryer - Gas
Maytag MDG8416AWW Dryer - Gas
International MDG8426AAW Dryer - Gas
International MDG8426AEW Dryer - Gas
International MDG8426AGW Dryer - Gas
Maytag MDG8500BWW Dryer - Gas
Maytag MDG8506AWA Dryer - Gas
Maytag MDG8506AWW Dryer - Gas
International MDG8550AGW Dryer - Gas
International MDG8550BGW Dryer - Gas
Maytag MDG8600AWQ Dryer - Gas
Maytag MDG8600AWW Dryer - Gas
Maytag MDG8757AWQ Dryer - Gas
Maytag MDG8757AWW Dryer - Gas
Maytag MDG9206AWA Dryer - Gas
Maytag MDG9206AWW Dryer - Gas
Maytag MDG9206AXW Dryer - Gas
Maytag MDG9206BWW Dryer - Gas
Maytag MDG9306AWA Dryer - Gas
Maytag MDG9306AWW Dryer - Gas
Maytag MDG9306AXA Dryer - Gas
Maytag MDG9306AXW Dryer - Gas
Maytag MDG9316AWA Dryer - Gas
Maytag MDG9316AWQ Dryer - Gas
Maytag MDG9316AWW Dryer - Gas
Maytag MDG9316AXW Dryer - Gas
Maytag MDG9316BWQ Dryer - Gas
Maytag MDG9316BWW Dryer - Gas
Maytag MDG9357AWA Dryer - Gas
Maytag MDG9357AWQ Dryer - Ele
Maytag MDG9357AWW Dryer - Gas
Maytag MDG9360BWW Dryer - Gas
Maytag MDG9390AWW Dryer - Gas
Maytag MDG9390AXW Dryer - Gas
Maytag MDG9390BWW Dryer - Gas
Maytag MDG9420BWW Dryer - Gas
Maytag MDG9520BWQ Dryer - Gas
Maytag MDG9520BWW Dryer - Gas
Maytag MDG9557AWA Dryer - Gas
Maytag MDG9557AWQ Dryer - Gas
Maytag MDG9557AWW Dryer - Gas
Maytag MDG9557AXQ Dryer - Gas
Maytag MDG9557AXW Dryer - Gas
Maytag MDG9557BWQ Dryer - Gas
Maytag MDG9557BWW Dryer - Gas
Maytag MDG9606AWA Dryer - Gas
Maytag MDG9606AWQ Dryer - Gas
  #2 (permalink)
Old 07-19-2007, 11:00 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Default
Karl
Most likely the problem with your dryer is a bad control board. It is not repairable and has to be replaced. The part number for the new control board is AP3882440 and you can buy it for $145.49.
The breakdown diagrams for the Maytag dryer with the model number MDG5500AWW you can find here: Model MDG5500AWW
If you need the complete step by step instructions how to replace the control board I'll be glad to help you.
Good luck.
  #3 (permalink)
Old 12-09-2007, 04:49 PM
jdappl07 jdappl07 is offline
Senior Expert
APP Volunteer
jdappl07 is on a distinguished road
Default
first i would check the power wires at the teminal block where you screwed the cord to make sure the screws are tught after you unplug it of couse
__________________
J&D Appliance Repair Serving Pendleton County, Kentucky and Surrounding Areas
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
