Discuss
Dryer not drying
 in
Dryer Repair
Wow - this is a brilliant forum. Initial problem was the automatic dry time not working. Now, my dryer is taking
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Dryer not drying
  #1 (permalink)
Old 12-30-2007, 02:37 PM
mariebw mariebw is offline
Junior Member
mariebw is on a distinguished road
Default Dryer not drying
Model Number: LGR3624 JQ1   Brand: Whirlpool   Age: 1 - 5 years
Wow - this is a brilliant forum. Initial problem was the automatic dry time not working. Now, my dryer is taking at leat 2 cycles to dry properly. Vents and lint areas have been thoroughly cleaned. I have ran it on a dry cycle, without the vent hose attached and checked the inside of the dryer intermittently, sometimes initially it's hot and then it remains cold. I can smell gas after about 20 mins.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 12-30-2007, 02:48 PM
Junior Member
Default
it has not dried the clothes with the vent off and the gas smell appears to be coming from the insode of the dryer.
  #3 (permalink)
Old 12-30-2007, 04:11 PM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
Remove the little access white plastic cover on the front panel on the bottom and check the flame, should be blueish. If it goes out after a short period of time, you need to replace the gas valve coils. Just click on your model # to get the part no's.
__________________
  #4 (permalink)
Old 12-30-2007, 05:39 PM
Junior Member
Default thanks
thanks for the quick respone - that seems to be the problem.
Marie
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag dryer drying slowly stodtmeister Dryer Repair 3 12-12-2007 06:12 PM
Dryer stopped mid drying cycle and won't start again scsimpson Dryer Repair 2 11-25-2007 07:44 PM
Dryer not drying sue1759 Dryer Repair 5 11-02-2007 06:09 PM
Top of Dryer hot but clothes not drying sween Dryer Repair 4 10-27-2007 01:29 PM
Gas Dryer not drying during run cycles GMP Dryer Repair 1 09-28-2007 08:42 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
