| » Gas Dryer smells like gas is leaking |
Model Number: DV219GW/XAA Brand: Samsung Age: Less than 1 year
***EDIT***
The model # is DV219AGW/XAA I bought a washer and dryer from Sears outlet last year and finally got around to installing them recently. Washer works awesome but the dryer is gas and smells like there is a gas leak. Even when the dryer is not running it has a gas smell, I want to say it is worse when it is running but I didn't leave the gas on too long to figure out when it smelled worse. I used a new flexible gas supply line and I soaped the all of the connections going to the dryer. My guess is that there is something wrong with the dryer and that may or may not be why it was at the outlet store. Both appliances looked brand new but I don't really know the history on them. What should I be looking for to solve this issue? I'm thinking the gas valve in the dryer is bad. Any help would be very appreciated! It also smelled like gas inside the dryer when it was connected to the gas and I was testing it and It did get hot. Ads By Google Related Models Last edited by Replacement : 12-16-2011 at 09:32 AM. |
I could not locate a service manual for this model dryer.
I will do some asking around. If you find one please consider sharing it with me.
__________________
ApplianceJunk.com ~ DIY Appliance Repair Forum |
Hi. Use bubble leak detctor Part number: AP3766089
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
We smell gas when opening our 24-year-old Whirlpool dryer after it has been on. Is this likely to be a connection, valve, coil, or what? We'll try the soap test on the gas line but suspect that's okay. Is it worth repairing if it's the valve? The dryer still dries well, though it rumbles loudly and we are considering replacing the rollers and shafts, which seems to be a minor cost if the gas valve isn't a problem.
Hi. We first need your model # to get you the correct part #'s. If the dryer cabinet is still in good shape and the overall consideration of shopping and replacing the unit -vs- part replacement is under 50% total replacement cost, then it is worth repair (parts availability consideration as well). The new gas valve should come with the coils as well. A new ignitor, belt and rollers (thumping noise) will help as well. Thank You.
Quote:
__________________
Quote:
As it turns out I think the gas problem is okay. The gas smell never happened again, and we went ahead with the replacement of the right roller which helped the noisy situation considerably, and we also have the inside a good cleaning. The gas valve seems to work fine and the flame is strong. The left roller, however was a problem--I couldn't figure out how to get the tinnerman (?) clip off since it is so tight against the triangle clip, and there is still a "ch-ch-ch-ch" noise (about 10x per drum revolution). The left roller looks okay but could that sound be from a slight invisible wearing of the roller? Or could it be the felt bearing around the front of the drum? Otherwise the dryer is still working fine and heats well. |
| Display Modes | |
| dryer smells | rmk | Dryer Repair | 1 | 06-24-2009 05:10 PM |
| dryer smells | rmk | Dryer Repair | 1 | 06-23-2009 02:49 AM |
| Dryer sometimes doesn't dry and smells burnt | wasabismom | Dryer Repair | 2 | 03-13-2009 10:41 AM |
| Dryer leaks and smells | M Holly | Dryer Repair | 1 | 11-19-2007 09:35 PM |
| dryer smells | ginny | Dryer Repair | 2 | 10-20-2007 02:42 AM |
