Discuss
Dryer won't Heat tumbles and blows air though
 in
Dryer Repair
Ok The dryer was taking too long to dry at first. It heated fine but not moving air. I cleaned
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Dryer won't Heat tumbles and blows air though
  #1 (permalink)
Old 06-27-2009, 01:44 PM
Junior Member
stacyvelazco is on a distinguished road
Question Dryer won't Heat tumbles and blows air though
Model Number: lcr764ko1   Brand: Whirlpool   Age: 5 - 10 years
Ok
I cleaned out the lint and replaced the exhaust tube.
Now it blows air and tumbles fine but no heat.
Please help....I have three kids and a huge pile of laundry!
Ads By Google
Related Models
Maytag LCRE200 Range - F/s Std Ele
Maytag LCRE300 Range - F/s Std Ele
Maytag LCRE305 Range - F/s Std Ele
Maytag LCRE350 Range - F/s Std Ele
Maytag LCRE355 Range - F/s Std Ele
Maytag LCRE383 Range - F/s Std Ele
Maytag LCRE400 Range - F/s Std Ele
Maytag LCRE600 Range - F/s Std Ele
Maytag LCRE650 Range - F/s Std Ele
Maytag LCRE655 Range - S/c F/s Ele
Maytag LCRE682 Range - S/c F/s Ele
Maytag LCRE683 Range - S/c F/s Ele
Maytag LCRE700 Range - S/c F/s Ele
Maytag LCRE750 Range - S/c F/s Ele
Maytag LCRE775 Range - S/c F/s Ele
Maytag LCRE800 Range - S/c F/s Ele
Maytag LCRE805 Range - S/c F/s Ele
Maytag LCRE883 Range - S/c F/s Ele
Maytag LCRG200 Range - F/s Std Gas
Maytag LCRG300 Range - F/s Std Gas
Maytag LCRG305 Range - F/s Std Gas
Maytag LCRG350 Range - F/s Std Gas
Maytag LCRG355 Range - F/s Std Gas
Maytag LCRG382 Range - F/s Std Gas
Maytag LCRG383 Range - F/s Std Gas
Maytag LCRG400 Range - F/s Std Gas
Maytag LCRG405 Range - F/s Cont Clean Gas
Maytag LCRG500 Range - F/s Std Gas
Maytag LCRG501 Range - F/s Std Gas
Maytag LCRG502 Range - F/s Std Gas
Maytag LCRG505 Range - F/s Std Gas
Maytag LCRG560 Range - F/s Std Gas
Maytag LCRG583 Range - F/s Cont Clean Gas
Maytag LCRG600 Range - F/s Std Gas
Maytag LCRG601 Range - F/s Std Gas
Maytag LCRG602 Range - F/s Cont Clean Gas
Maytag LCRG700 Range - S/c F/s Gas
Maytag LCRG705 Range - S/c F/s Gas
Maytag LCRG750 Range - S/c F/s Gas
Maytag LCRG755 Range - S/c F/s Gas
Maytag LCRG760 Range - S/c F/s Gas
Maytag LCRG760A Range - S/c F/s Gas
Maytag LCRG783 Range - S/c F/s Gas
Maytag LCRG800 Range - S/c F/s Gas
Maytag LCRG805 Range - S/c F/s Gas
Maytag LCRG860 Range - S/c F/s Gas
Maytag LCRG860A Range - S/c F/s Gas
Maytag LCRP200 Range - F/s Std Gas
Maytag LCRP205 Range - F/s Std Gas
Maytag LCRP300 Range - F/s Std Gas
Maytag LCRP382 Range - F/s Std Gas
Maytag LCSE400 Surface Unit - Ele
Maytag LCSE600 Surface Unit - Ele
Maytag LCSE601 Surface Unit - Ele
Maytag LCSG500 Surface Unit - Gas
Maytag LCSG501 Surface Unit - Gas
Maytag LCSG560 Surface Unit - Gas
Maytag LCSG600 Surface Unit - Gas
Amana LCU-514 Range - S/c S/i Ddraft Gas
Amana LCU-514D Range - S/c S/i Ddraft Gas
Amana LCU-514E Range - S/c S/i Ddraft Gas
Amana LCU-516D Range - S/c S/i Ddraft Gas
Amana LD10 Commercial Microwaves
Amana LD10D Commercial Microwaves
Amana LD10D2  Commercial Microwaves
Amana LD10MP  Commercial Microwaves
Amana LD10MPS  Commercial Microwaves
Amana LD510 Commercial Microwaves
Amana LD510D  Commercial Microwaves
Amana LD510M Commercial Microwaves
Amana LD510P  Commercial Microwaves
Amana LD510S Commercial Microwaves
Gaggenau LD816-610
Gaggenau LD816-620
Whirlpool LDA3000W0
Whirlpool LDA3000W1
Whirlpool LDA3000W2
Whirlpool LDA3000W3
Whirlpool LDA3005W0
Whirlpool LDA3005W1
Whirlpool LDA3005W2
Whirlpool LDA3005W3
Whirlpool LDA3800W0
Whirlpool LDA3805W0
Whirlpool LDA4000W0
Whirlpool LDA4000W1
Whirlpool LDA4000W2
Whirlpool LDA4000W3
Whirlpool LDA4005W0
Whirlpool LDA4005W1
Whirlpool LDA4005W2
Whirlpool LDA4005W3
Whirlpool LDA5300W0
Whirlpool LDA5300W1
Whirlpool LDA5300W2
Whirlpool LDA5300W3
Whirlpool LDA5380W0
Whirlpool LDA5380W1
Whirlpool LDA5380W2
Whirlpool LDA5380W3
Whirlpool LDA5500W0
Whirlpool LDA5500W1
Whirlpool LDA5500W2
Whirlpool LDA5500W3
Whirlpool LDA5505W0
Whirlpool LDA5505W1
Whirlpool LDA5505W2
Whirlpool LDA5505W3
Whirlpool LDA5520W1
Whirlpool LDA5520W2
Whirlpool LDA5520W3
Whirlpool LDA5525W1
Whirlpool LDA5525W2
Whirlpool LDA5525W3
Whirlpool LDA5600W1
Whirlpool LDA5600W2
Whirlpool LDA5600W3
Whirlpool LDA5605W1
Whirlpool LDA5605W2
Whirlpool LDA5605W3
  #2 (permalink)
Old 06-27-2009, 05:08 PM
Senior Expert
APP Volunteer
magician59 will become famous soon enough
Default
First, check the vent to see if it's clogged or obstructed e.g. crimped flex hose, bird or squirrel nest, lint, etc. This condition can cause the drying time to gradually increase, and, as probable in your case, one or more of the thermostats to open.
  #3 (permalink)
Old 06-28-2009, 11:59 AM
Junior Member
Unhappy Vent was clogged.
OK so I took off the Back and cleaned all of the lint and replaced the exhaust tubing. Still doesn't want to heat.
  #4 (permalink)
Old 06-28-2009, 08:18 PM
Senior Expert
APP Volunteer
Default
Do you have a multi-meter? Can you check the thermostats?
  #5 (permalink)
Old 06-29-2009, 10:34 PM
Junior Member
Default
My dad Came over and checked the thermostats The ignition everything looks ok.... But when he turned it on he said he didn't hear the "whoosh" of the gas going on..
  #6 (permalink)
Old 06-30-2009, 05:52 AM
Senior Expert
APP Volunteer
Default
Quote:
There are a couple really common causes for no-heat problems on a gas dryer, and one that is less common: Check to see if the ignitor is glowing. If not, replace it (be careful not to contaminate its element by direct touch [similar to the caution in handling your car's headlamps]). If you see it glow, and cycle on and off, the coils should be replaced (their function is to open and close the gas valve).
The less common failure is the radiant sensor. Its function is to sense the glow of the ignitor and allow current to flow to the coils, so that the gas does not flow in the case of a radiant or flame failure.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
dryer tumbles, but no heat sugarman45 Dishwasher Repair 1 10-29-2009 04:27 PM
Dryer will not heat. It tumbles and cycles but it will not emit any heat. agentsmith0505 Dryer Repair 0 10-14-2009 09:44 AM
gas dryer tumbles but no heat GEE1949 Dryer Repair 0 10-08-2009 02:53 PM
Gas dryer tumbles with air but no heat Harry III Dryer Repair 7 08-23-2009 07:26 AM
My dryer tumbles but does not heat cyn2teaseu Dryer Repair 6 12-12-2008 07:54 AM
