Discuss
No heat and setting dial does not turn
 in
Dryer Repair
When I close the door and hit the start button the dryer turns but does not warm. Also the setting
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » No heat and setting dial does not turn
  By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 06-27-2009, 09:15 AM
Junior Member
TOG1 is on a distinguished road
Default No heat and setting dial does not turn
Model Number: LGR5636JQ0   Brand: Whirlpool   Age: 5 - 10 years
When I close the door and hit the start button the dryer turns but does not warm. Also the setting knob does not move and the dryer will run all day if I don't open the door. Is this something that I can fix on my own? I have been laid off for a while and really can't afford to pay someone to fix it.
thanks
Tom
Related Models
Whirlpool LGR5636JQ0 DRYER
Whirlpool LGR5636JQ1 DRYER
Whirlpool LGR5636JT0 DRYER
Whirlpool LGR5636JT1 DRYER
Whirlpool LGR5636KQ0 DRYER
Whirlpool LGR5636KQ1 DRYER
Whirlpool LGR5636KT0 DRYER
Whirlpool LGR5636KT1 DRYER
Whirlpool LGR5636LG0 RESIDENTIAL DRYER
Whirlpool LGR5636LQ0 RESIDENTIAL DRYER
Whirlpool LGR5636LQ1 29"GAS DRYER
Whirlpool LGR5636LT0 RESIDENTIAL DRYER
Whirlpool LGR5636LT1 29"GAS DRYER
Whirlpool LGR5636LW0 RESIDENTIAL DRYER
Whirlpool LGR5636PQ0 29"GAS DRYER
Whirlpool LGR5636PQ1 29"GAS DRYER
Whirlpool LGR5636PT0 29"GAS DRYER
Whirlpool LGR5636PT1 29"GAS DRYER
Whirlpool LGR5638AN1 GAS DRYER
Whirlpool LGR5638AN2 GAS DRYER
Whirlpool LGR5638AN3 GAS DRYER
Whirlpool LGR5638AW0 Residential Dryer
Whirlpool LGR5638AW1 GAS DRYER
Whirlpool LGR5638AW2 GAS DRYER
Whirlpool LGR5638AW3 GAS DRYER
Whirlpool LGR5644AN1
Whirlpool LGR5644AN2 GAS DRYER
Whirlpool LGR5644AW0 Residential Dryer
Whirlpool LGR5644AW1
Whirlpool LGR5644AW2 GAS DRYER
Whirlpool LGR5644EQ0 GAS DRYER
Whirlpool LGR5644EQ1 DRYERS
Whirlpool LGR5644EQ2 GAS DRYER
Whirlpool LGR5644EQ3 GAS DRYER
Whirlpool LGR5644EZ0 GAS DRYER
Whirlpool LGR5644EZ1 DRYERS
Whirlpool LGR5644EZ2 GAS DRYER
Whirlpool LGR5644EZ3 GAS DRYER
Whirlpool LGR5644JQ0 GAS DRYER
Whirlpool LGR5644JQ1 RESIDENTIAL DRYER
Whirlpool LGR5644JQ2 GAS DRYER
Whirlpool LGR5644JQ3 29" GAS DRYER
Whirlpool LGR5644JT0 GAS DRYER
Whirlpool LGR5644JT1 RESIDENTIAL DRYER
Whirlpool LGR5644JT2 GAS DRYER
Whirlpool LGR5644JT3 29" GAS DRYER
Whirlpool LGR5644PQ0 29" GAS DRYER
Whirlpool LGR5644PQ1 29" GAS DRYER
Whirlpool LGR5700KQ0 DRYER
Whirlpool LGR5700KQ1 DRYER
Whirlpool LGR5700KT0 DRYER
Whirlpool LGR5700KT1 DRYER
Whirlpool LGR5848EQ0 GAS DRYER
Whirlpool LGR5848EQ1 GAS DRYER
Whirlpool LGR5848EQ2 GAS DRYER
Whirlpool LGR5848EQ3 DRYERS
Whirlpool LGR5848EQ4 DRYERS
Whirlpool LGR5848EQ5 GAS DRYER
Whirlpool LGR5848EQ6 GAS DRYER
Whirlpool LGR6611LQ0 RESIDENTIAL DRYER
Whirlpool LGR6611LQ1 29"GAS DRYER
Whirlpool LGR6611PQ0 29" GAS DRYER
Whirlpool LGR6620PQ0 29"GAS DRYER
Whirlpool LGR6620PQ1 29"GAS DRYER
Whirlpool LGR6620PT0 29"GAS DRYER
Whirlpool LGR6620PT1 29"GAS DRYER
Whirlpool LGR6621PQ0 29" GAS DRYER
Whirlpool LGR6634BN0 GAS DRYER
Whirlpool LGR6634BN1 GAS DRYER
Whirlpool LGR6634BN2 GAS DRYER
Whirlpool LGR6634BQ0 GAS DRYER
Whirlpool LGR6634BQ1 GAS DRYER
Whirlpool LGR6634BQ2 GAS DRYER
Whirlpool LGR6634BW0 GAS DRYER
Whirlpool LGR6634BW1 GAS DRYER
Whirlpool LGR6634BW2 GAS DRYER
Whirlpool LGR6634DQ0 GAS DRYER
Whirlpool LGR6634DQ1 GAS DRYER
Whirlpool LGR6634DW0 GAS DRYER
Whirlpool LGR6634DW1 GAS DRYER
Whirlpool LGR6634DZ0 GAS DRYER
Whirlpool LGR6634DZ1 GAS DRYER
Whirlpool LGR6636PW0 29" GAS DRYER
Whirlpool LGR6636PW1 29" GAS DRYER
Whirlpool LGR6638DQ0 GAS DRYER
Whirlpool LGR6638DQ1 GAS DRYER
Whirlpool LGR6638DW0 GAS DRYER
Whirlpool LGR6638DW1 GAS DRYER
Whirlpool LGR6638DZ0 GAS DRYER
Whirlpool LGR6638DZ1 GAS DRYER
Whirlpool LGR6644DQ0 GAS DRYER
Whirlpool LGR6644DQ1 GAS DRYER
Whirlpool LGR6644DZ0 GAS DRYER
Whirlpool LGR6644DZ1 GAS DRYER
Whirlpool LGR6646BN0 GAS DRYER
Whirlpool LGR6646BN1 GAS DRYER
Whirlpool LGR6646BN2 GAS DRYER
Whirlpool LGR6646BW0 GAS DRYER
Whirlpool LGR6646BW1 GAS DRYER
Whirlpool LGR6646BW2 GAS DRYER
Whirlpool LGR6646DN1 GAS DRYER
Whirlpool LGR6646DW1 GAS DRYER
Whirlpool LGR6646PW0 29" GAS DRYER
Whirlpool LGR6646PW1 29" GAS DRYER
Whirlpool LGR6848AN1 GAS DRYER
Whirlpool LGR6848AN2 GAS DRYER
Whirlpool LGR6848AQ2 GAS DRYER
Whirlpool LGR6848AW0 Residential Dryer
Whirlpool LGR6848AW1 GAS DRYER
Whirlpool LGR6848AW2 GAS DRYER
Whirlpool LGR6848AZ2 GAS DRYER
Whirlpool LGR7620KQ0 RESIDENTIAL DRYER
Whirlpool LGR7620KQ1 RESIDENTIAL DRYER
Whirlpool LGR7620KT0 RESIDENTIAL DRYER
Whirlpool LGR7620KT1 RESIDENTIAL DRYER
Whirlpool LGR7620LG0 RESIDENTIAL DRYER
Whirlpool LGR7620LG1 29"GAS DRYER
Whirlpool LGR7620LQ0 RESIDENTIAL DRYER
Whirlpool LGR7620LW0 RESIDENTIAL DRYER
Whirlpool LGR7620LW1 29"GAS DRYER
  #2 (permalink)
Old 06-29-2009, 01:00 PM
Senior Expert
APP Volunteer
sidfink43 is a jewel in the rough
Default
Hi Tog1
Sorry about your layoff, it's become the norm these days so you are not alone.
You should be able to fix this dryer by yourself, but you will need a test meter (or even better, a friend who has one and knows how to use it)
Take off the back cover and test each of these components for continuity.
1. Thermal Fuse
2. Thermostat
3. High Limit Thermostat
It is likely you will find an open circuit in one of them, if so, replace it and you will be back in business.
If they are all good the problem is likely in your burner system and if you look at the many posts on this site involving gas dryer will not come on I think you will find how to fix yours.
Good luck, let us know what you find out.
__________________
  #3 (permalink)
Old 07-06-2009, 10:43 AM
Junior Member
Default
I checked the thermal fuse and the thermostats and they seem ok. Before I get into the burner system could it be the timer since it is not moving? I set it and it will run all day if I let it. I also checked the vent and don't see any problems there. How do i check the igniter? I'm not sure how to get to it.
Tom
  #4 (permalink)
Old 07-06-2009, 02:33 PM
Senior Expert
APP Volunteer
Default
HiTog1
I do not work on gas appliances, so I think you should review the posts on this Forum involving them and see what they say. Most of them report success by replacing the gas coils, which is what I would recommend before doing anything else. You will also see disucssions of the igniter and the flame sensor which could be causing your problem.
Your timer may be such that it will not advance without heat. Is it not advancing in the auto cycle or the timed cycle?
Anyway, I would try to get your heat issues solved, and then see if you need a timer, since it is a more expensive part.
Good luck, let us know what you do
__________________
  #5 (permalink)
Old 07-06-2009, 09:33 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hi Tom,
The timer is the last thing I would suspect in such situation. Check the igniter. Normally it should be about 40 Ohms resistance reading. Check the gas valve coils as described in one of our previous posts: dryer runs but no heat
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL LGR5636JQ0 | AppliancePartsPros.com
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE Knob does not turn dial Duane Luetkenhaus Washer Repair 1 11-04-2009 12:20 PM
kenmore oven not heating to dial setting kings113 Oven Repair (including Ranges and Cooktops) 0 12-14-2008 06:17 PM
defective cycle control knob won't push in; need to grasp & turn wash cycle dial. lewisj Washer Repair 1 11-10-2008 10:03 AM
Gas oven will not heat to setting darthrethaf005 Oven Repair (including Ranges and Cooktops) 1 06-12-2008 04:03 PM
Bake setting provides no heat adrielus Oven Repair (including Ranges and Cooktops) 6 12-18-2007 06:21 AM
