Discuss
Fde436res2
 in
Dryer Repair
My drier works fine, although it will not shut off no matter how many mins. I set it for, it
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Fde436res2
  #1 (permalink)
Old 12-13-2011, 06:39 PM
Junior Member
bob waterhouse is on a distinguished road
Default Fde436res2
Brand: Frigidaire   Age: 5 - 10 years
My drier works fine, although it will not shut off no matter how many mins. I set it for, it will not start if the timer is set to zero.
It will however shut off if I manually turn the timer to zero.
Any Ideas?
Bob
Ads By Google
  #2 (permalink)
Old 12-14-2011, 05:31 AM
Senior Expert
APP Volunteer
denman is a glorious beacon of light
Default
Here are your parts includes a wiring diagram.
Wiring diagram replacement parts for FRIGIDAIRE FDE436RES2 Frg(v1) / Electric Dryer | AppliancePartsPros.com
Here is the wiring diagram that may be easier to read.
http://manuals.frigidaire.com/prodin.../131850400.pdf
Does the timer advance?
Try it in both timed dry and auto modes.
The timer motor gets it's power through different circuits in each mode.
Direct from the line when in timed dry.
Through the heating coil when it is shut off by the thermostat when in auto.
If it does not advance in timed dry then odds are high that the timer is toast.
This can be checked by checking if it gets power (120 volts).
If it does and does not advance then the timer needs replacing.
Be very careful when checking this as there is 240 volts at the timer and that is lethal.
If it does advance in timed dry but not auto then check the heating coil and the 4,400 ohm resistor in the timer motor circuit.
__________________
  #3 (permalink)
Old 12-14-2011, 05:18 PM
Junior Member
Default
Thanks for the help, the timer does not advance in either timed or auto mode.
My wife just told me the cloths also seem hotter than normal, could that be maybe a temp sensor?
Bob
  #4 (permalink)
Old 12-15-2011, 05:12 AM
Senior Expert
APP Volunteer
Default
Since it does not advance in timed dry odds are the timer is toast as it's motor gets power directly from the line in this mode.
When it is running the circuit path is from Neutral thru the motors centrifugal switch to X/TM timer contacts, thru the motor the thru C/B timer contacts to L1 (120 volts).
This can be checked by measuring the voltage across the timer motor (TM to C on the timer) when it is running in timed dry mode. If it has 120 volts and the timer does not advance the timer is toast.
Be very careful if you do this as there is 240 volts at the timer and that is lethal!!!
It could be but is unlikely.
More likely is that your vent system needs cleaning.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
