Discuss
Timer goes in reverse
 in
Dryer Repair
The dryer works but the timer goes in reverse. Do I have to replace the timer?
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Timer goes in reverse
  #1 (permalink)
Old 12-29-2007, 10:32 AM
joex joex is offline
Junior Member
joex is on a distinguished road
Default Timer goes in reverse
Model Number: 97283100   Brand: Kenmore   Age: More than 10 years
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 12-29-2007, 10:40 AM
misterfixall misterfixall is offline
Senior Expert
APP Volunteer
misterfixall is on a distinguished road
Default
are you saying timer turns counter clockwise? right to left? how does the dryer behave other than that?
__________________
  #3 (permalink)
Old 12-29-2007, 10:52 AM
Junior Member
Default
Yes, the timer turns counter clockwise. This occurs in the auto dry cycle. The dryer will dry but since it goes in reverse the time is shortened. Not sure what happens in the other cycles.
  #4 (permalink)
Old 12-29-2007, 02:18 PM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
You probably have a black plastic housing on your timer and the timer motor screws on the back of it. There is a motor mounted non the gear train, that has been polled to run backward, you will need to replace it. Unfortunately they do not sell it, need to buy a new timer unless you can get one used. Most timer motors of the age dryer where the same and turned the same direction.
__________________
  #5 (permalink)
Old 01-06-2008, 08:11 PM
Junior Member
Default
thanks for your help. I replaced the timer and it is now working.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Broken Timer? drew1107 Washer Repair 1 11-14-2007 08:47 PM
Defrost timer Greta Elliott Refrigerator & Freezer Repair 2 11-04-2007 01:58 AM
Timer does not advance Lloyd Kneller Washer Repair 1 09-26-2007 03:18 AM
range/timer ewallen Oven Repair (including Ranges and Cooktops) 0 09-24-2007 03:35 PM
Timer again??? 4dugnlee Washer Repair 8 08-17-2007 07:45 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
