cjagadheshan
#1 Posted : Tuesday, December 13, 2011 5:11:32 PM(UTC)
cjagadheshan
My Kenmore Elite Dryer (110.64982301) runs but does not heat.
Will I be able to get the Service manual and troubleshooting steps for this.
#2 Posted : Wednesday, December 14, 2011 4:50:52 AM(UTC)
Replacement parts for KENMORE 11064982301 | AppliancePartsPros.com
First check the power. The lights, motor and control board use 120 volts but the heating coil requires the full 240.
Try flipping the breaker off/on slowly a couple times.
Sometimes you can loose half the line without actually tripping the breaker.
If this does nothing, check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
If power is OK
Unplug the unit and check the heating coil, should be around 10 ohms.
If OK
Try swapping the heater relay and the motor relay. I think they are the same but double check that they are before doing the swap.
File Attachment(s):
64982301.pdf (390kb) downloaded 38 time(s).
