Discuss
frigidaire electric dryer
 in
Dryer Repair
No power at all - worked for one load died on the next. Looking to replace the hi temp thermal
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » frigidaire electric dryer
  #1 (permalink)
Old 06-25-2009, 06:38 AM
Junior Member
GaydosBlessed is on a distinguished road
Default frigidaire electric dryer
Model Number: leq2152eso   Brand: Frigidaire   Age: 1 - 5 years
Looking to replace the hi temp thermal fuse but not sure if that will solve the problem. I need my dryer back.
Ads By Google
Related Models
Frigidaire LEQ2152HS0 DRYER
Frigidaire LEQ332DS0 Frigidaire/dryer
Whirlpool LEQ5000KQ0 DRYER
Whirlpool LEQ5000KQ1 29"ELECTRIC DRYER
Whirlpool LEQ5000KQ2 29"ELECTRIC DRYER
Whirlpool LEQ5000KW1 29"ELECTRIC DRYER
Whirlpool LEQ5000KW2 29"ELECTRIC DRYER
Whirlpool LEQ5000PW0 29"ELECTRIC DRYER
Frigidaire LEQ6000ES0 Frigidaire/dryer
Frigidaire LEQ6000ES1 Frigidaire/dryer
Frigidaire LEQ6000ES2 Frigidaire/electric Dryer
Frigidaire LEQ6400FS0 DRYER
Frigidaire LEQ642DS0 Frigidaire/dryer
Frigidaire LEQ7000EG0 Frigidaire/dryer
Frigidaire LEQ7000ES0 Frigidaire/dryer
Frigidaire LEQ7000ES1 Frigidaire/dryer
Frigidaire LEQ7000ES2 Frigidaire/dryer
Whirlpool LEQ7000KQ0 DRYER
Whirlpool LEQ7000KQ1 DRYER
Whirlpool LEQ7000KQ2 DRYER
Whirlpool LEQ7030KQ0 DRYER
Whirlpool LEQ7030KQ1 RESIDENTIAL DRYER
Whirlpool LEQ7030KQ2 29"ELECTRIC DRYER
Frigidaire LEQ8000FE0 DRYER
Whirlpool LEQ8000HQ0 DRYER
Whirlpool LEQ8000HQ1 DRYER
Whirlpool LEQ8000JQ0 DRYER
Whirlpool LEQ8000JQ1 DRYER
Whirlpool LEQ8000JQ2 DRYER
Whirlpool LEQ8000JQ3 29"ELECTRIC DRYER
Whirlpool LEQ8000JQ4 ELECTRIC DRYER
Whirlpool LEQ8100KQ0 DRYER
Whirlpool LEQ8100KQ1 DRYER
Whirlpool LEQ8100KT0 DRYER
Whirlpool LEQ8100KT1 DRYER
Whirlpool LEQ8611LG0 RESIDENTIAL DRYER
Whirlpool LEQ8611LG1 27"ELECTRIC DRYER
Whirlpool LEQ8611LW0 RESIDENTIAL DRYER
Whirlpool LEQ8611LW1 27"ELECTRIC DRYER
Whirlpool LEQ8611PG0 27" ELECTRIC DRYER
Whirlpool LEQ8611PG1 27"ELECTRIC DRYER
Whirlpool LEQ8611PG2 27"ELECTRIC DRYER
Whirlpool LEQ8611PW0 27" ELECTRIC DRYER
Whirlpool LEQ8611PW1 27"ELECTRIC DRYER
Whirlpool LEQ8611PW2 27"ELECTRIC DRYER
Whirlpool LEQ8621PG0 27" ELECTRIC DRYER
Whirlpool LEQ8621PG1 27"ELECTRIC DRYER
Whirlpool LEQ8621PG2 27"ELECTRIC DRYER
Whirlpool LEQ8621PW0 27" ELECTRIC DRYER
Whirlpool LEQ8621PW1 27"ELECTRIC DRYER
Whirlpool LEQ8621PW2 27"ELECTRIC DRYER
Whirlpool LEQ8800JQ0 DRYER
Whirlpool LEQ8800JQ1 DRYER
Whirlpool LEQ8800JT0 DRYER
Whirlpool LEQ8800JT1 DRYER
Whirlpool LEQ8857HQ0 DRYER
Whirlpool LEQ8857HQ1 DRYER
Whirlpool LEQ8857HZ0 DRYER
Whirlpool LEQ8857HZ1 DRYER
Whirlpool LEQ8857JQ0 DRYER
Whirlpool LEQ8857JQ1 DRYER
Whirlpool LEQ8857JT0 DRYER
Whirlpool LEQ8857JT1 DRYER
Whirlpool LEQ8858HQ0 DRYER
Whirlpool LEQ8858HQ1 DRYER
Whirlpool LEQ8858HZ0 DRYER
Whirlpool LEQ8858HZ1 DRYER
Whirlpool LEQ8858JQ0 DRYER
Whirlpool LEQ8858JQ1 DRYER
Whirlpool LEQ8858JT0 DRYER
Whirlpool LEQ8858JT1 DRYER
Whirlpool LEQ8858JZ1 DRYER
Whirlpool LEQ9030PQ0 29"ELECTRIC DRYER
Whirlpool LEQ9030PQ1 29" ELECTRIC DRYER
Whirlpool LEQ9508KQ0 RESIDENTIAL DRYER
Whirlpool LEQ9508LG0 RESIDENTIAL DRYER
Whirlpool LEQ9508LW0 RESIDENTIAL DRYER
Whirlpool LEQ9508LW1 29"ELECTRIC DRYER
Whirlpool LEQ9508PG0 29"ELECTRIC DRYER
Whirlpool LEQ9508PG1 29" ELECTRIC DRYER
Whirlpool LEQ9508PW0 29"ELECTRIC DRYER
Whirlpool LEQ9508PW1 29" ELECTRIC DRYER
Whirlpool LEQ9557KQ1 RESIDENTIAL DRYER
Whirlpool LEQ9557KT1 RESIDENTIAL DRYER
Whirlpool LEQ9558KQ0 RESIDENTIAL DRYER
Whirlpool LEQ9558KQ1 RESIDENTIAL DRYER
Whirlpool LEQ9558KT0 RESIDENTIAL DRYER
Whirlpool LEQ9558KT1 RESIDENTIAL DRYER
Whirlpool LEQ9857LG0 RESIDENTIAL DRYER
Whirlpool LEQ9857LG1 29"ELECTRIC DRYER
Whirlpool LEQ9857LW0 RESIDENTIAL DRYER
Whirlpool LEQ9857LW1 29"ELECTRIC DRYER
Whirlpool LEQ9857PW0 29"ELECTRIC DRYER
Whirlpool LEQ9858LG0 RESIDENTIAL DRYER
Whirlpool LEQ9858LG1 29"ELECTRIC DRYER
Whirlpool LEQ9858LW0 RESIDENTIAL DRYER
Whirlpool LEQ9858LW1 29"ELECTRIC DRYER
Whirlpool LEQ9858PG0 29"ELECTRIC DRYER
Whirlpool LEQ9858PG1 29"ELECTRIC DRYER
Whirlpool LEQ9858PW0 29"ELECTRIC DRYER
Whirlpool LEQ9858PW1 29"ELECTRIC DRYER
Whirlpool LEQ9957KQ0 RESIDENTIAL DRYER
Whirlpool LEQ9957KT0 RESIDENTIAL DRYER
Admiral LER1115AAW RANGE- F/S STD ELE
Whirlpool LER2614BW0 ELECTRIC DRYER
Whirlpool LER2614BW1 ELECTRIC DRYER
Whirlpool LER2614BW2 ELECTRIC DRYER
Whirlpool LER2614DW0 ELECTRIC DRYER
Whirlpool LER2614DW1 ELECTRIC DRYER
Whirlpool LER2614EW0 ELECTRIC DRYER
Whirlpool LER2614EW1 ELECTRIC DRYER
Whirlpool LER2614EW2 ELECTRIC DRYER
Whirlpool LER2614JQ0 ELECTRIC DRYER
Whirlpool LER2614JQ1 ELECTRIC DRYER
Whirlpool LER2614JQ2 29"ELECTRIC DRYER
Frigidaire LER331DS0 Frigidaire/dryer
Admiral LER3330AAB RANGE- S/C F/S ELE
Admiral LER3330AAW RANGE- S/C F/S ELE
Admiral LER3330AAZ RANGE- S/C F/S ELE
Whirlpool LER3422AW0 Residential Dryer
  #2 (permalink)
Old 06-25-2009, 06:51 AM
Senior Expert
APP Volunteer
denman is a glorious beacon of light
Default
Replacement parts for FRG LEQ2152ES0 | AppliancePartsPros.com
Here is the tech sheet
http://manuals.frigidaire.com/prodin...509400efsa.pdf
Two ways to check it:
The Pro's Method
Unplug the unit.
Remove one wire from the fuse.
Measure it with a meter.
Should be 0 ohms.
The Jiggery Pokery Method
Unplug the unit.
Remove both wires from the fuse and short them together.
Tape them up so they cannot short to the frame etc.
Plug it in and give it a try.
If it is blown replace it ASAP as it is a critical safety device.
Give the interior including the blower wheel a good cleaning.
Also clean and check your vent system.
These are the most common causes of it blowing.
__________________
  #3 (permalink)
Old 06-26-2009, 12:55 PM
Junior Member
Thumbs down
I have the part now how do I replace it?
  #4 (permalink)
Old 06-27-2009, 05:05 AM
Senior Expert
APP Volunteer
Default
See the following
http://www.applianceaid.com/ww-and-mc.html
Would also be a good idea to clean and check the rear drum bearing.
Re-grease it with high temp grease.
Also check the belt etc.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Frigidaire Electric Dryer cafero99 Dryer Repair 2 08-20-2009 07:06 PM
Frigidaire Electric Dryer Not Heating tleelee Dryer Repair 2 03-31-2009 01:59 PM
frigidaire electric dryer mod#gleq2152eso whirpguy Dryer Repair 0 02-05-2009 02:11 PM
frigidaire electric dryer atlanta handyman Dryer Repair 2 11-20-2008 06:21 PM
Frigidaire electric dryer outlaw Dryer Repair 1 01-19-2008 06:42 PM
