Discuss
ge wsm2700wawww replacing heater element
 in
Dryer Repair
can not get ge service in my area. so i have to do it all myself... and i'm a
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » ge wsm2700wawww replacing heater element
  #1 (permalink)
Old 12-28-2007, 01:18 PM
bobatjsk bobatjsk is offline
Junior Member
bobatjsk is on a distinguished road
Question ge wsm2700wawww replacing heater element
Model Number: wsm2700wawww   Brand: GE   Age: 5 - 10 years
can not get ge service in my area. so i have to do it all myself... and i'm a clutz.
i'm trying to replace the heating element in the dryer. i have an exploded drawing (available from numerous web sites) which shows a lot but not enough. my assumption is that i must go in thru the front by removing the front panel. i remove the 4 screws at the top... then what. i don't see anything holding the panel on, yet... it wont come off.
any help would be appreciated. i can read a manual if i had one, but i've found nothing online.
tia.
bob
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 12-28-2007, 06:12 PM
abbie abbie is offline
Senior Expert
APP Volunteer
abbie is on a distinguished road
Default
BOB If i can recall when you take the 4 screws off the front you can tilt the top section back,but before i would do this I would go to the back of the dryer and take the belt off the idler pulley,then with the top section tilted, look in at the front panel.there will be a screw in each corner remove them and disconnect the lid switch wires.Now you can move the front panel by lifting up,move this to the side.Remove the drum/and belt all at once,by lifting the drum a little and going straight out.Now your at the heater. there is only 4 screws in the heater canister remove the 4 screws and wires going to the thermostats and element .REPLACE with the new part....good luck.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Replacing a glass top burner element billy_mc Oven Repair (including Ranges and Cooktops) 1 06-15-2008 09:11 PM
replacing bake element staceymoore01 Oven Repair (including Ranges and Cooktops) 2 06-13-2008 11:25 PM
No voltage to lower heater element buzz Oven Repair (including Ranges and Cooktops) 2 12-19-2007 08:40 AM
Heater Element Disconnected MMW Dishwasher Repair 4 12-05-2007 06:59 AM
replacing heater element Roy T Dryer Repair 1 11-11-2007 08:59 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
