Discuss
dryer won't heat
 in
Dryer Repair
I have a whirlpool estate gas dryer that will not heat. i have replaced the ignitor but that did not
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » dryer won't heat
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 12-28-2007, 12:04 PM
theltzel theltzel is offline
Junior Member
theltzel is on a distinguished road
Default dryer won't heat
Model Number: tgds84ojgo   Brand: Estate   Age: 5 - 10 years
I have a whirlpool estate gas dryer that will not heat. i have replaced the ignitor but that did not help. Any suggestions on what to try next.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 12-28-2007, 02:01 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Pull the dryer of the wall, unplug the power cord, remove the vent hose from the dryer and remove the back panel.
According to the bulkhead parts break down diagram start the troubleshooting from the thermal fuse (#7). Remove at least one wire from the thermal fuse and check the continuity across terminals.
If the thermal fuse is open it has to be replaced together with the cycling thermostat (#9).
If this is not an issue, go to the flame sensor(#49) and perform the same continuity test. Replace if it's open.
- The part number for the thermal fuse AP3132867
- The part number for the cycling thermostat AP3131939
- The part number for the flame sensor is AP2910747
- Here are the break down diagrams for the Whirlpool Estate dryer Model TGDS840JQ0
Good luck and Happy New year.
__________________
Professional appliance repair services in Orange County, California.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Gas Dryer no Heat KrazyK55 Dryer Repair 6 01-15-2008 01:22 PM
Dryer won't heat tomhickey Dryer Repair 1 12-23-2007 10:41 AM
dryer will not heat? radio963 Dryer Repair 1 11-09-2007 09:02 AM
Estate Dryer by Whirlpool/Dryer running but no heat tsm11238 Dryer Repair 1 11-06-2007 10:47 AM
No Dryer Heat jackd3 Dryer Repair 2 10-06-2007 12:32 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
