Discuss
Heat doesn't stay on
 in
Dryer Repair
Burner comes on but shuts off withing a couple of minutes. It does not matter what dying mode is being
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Heat doesn't stay on
  #1 (permalink)
Old 06-22-2009, 06:37 AM
Junior Member
rankshaft is on a distinguished road
Default Heat doesn't stay on
Model Number: TGDX640JQ2   Brand: Whirlpool   Age: 5 - 10 years
Burner comes on but shuts off withing a couple of minutes. It does not matter what dying mode is being used - high, low or dryness. The burner stays locked out for a considerable length of time and will not ignite in any drying mode position.
Related Models
 TGDX640JQ2 DRYER
 TGDX640JQ3 29"GAS DRYER
 TGDX640PQ0 29" GAS DRYER
 TGDX640PQ1 29"GAS DRYER
Tappan TGF303AWA Tappan/gas Range
Tappan TGF303BWA Tappan/gas Range
Tappan TGF303BWB Tappan/gas Range
Tappan TGF303BWC Tappan/gas Range
Frigidaire TGF303BWD Tappan/range
Tappan TGF303BWE Tappan/range
Tappan TGF303BWF GAS RANGE
Tappan TGF303BWG GAS RANGE
Tappan TGF316GSA GAS RANGE
Tappan TGF316GSB GAS RANGE
Tappan TGF316GSC GAS RANGE
Tappan TGF316GSD GAS RANGE
Tappan TGF316GSF GAS RANGE
Tappan TGF317AUA Tappan/range
Tappan TGF317AUB Tappan/gas Range
Tappan TGF317AWA Tappan/range
Tappan TGF317AWB Tappan/gas Range
Tappan TGF317BUA Tappan/gas Range
Tappan TGF317BUB Tappan/gas Range
Tappan TGF317BUC Tappan/gas Range
Tappan TGF317BWA Tappan/gas Range
Tappan TGF317BWB Tappan/gas Range
Tappan TGF317BWC Tappan/gas Range
Tappan TGF317DUA Tappan/gas Range
Tappan TGF317DUB Tappan/gas Range
Tappan TGF317DUC Tappan/range
Tappan TGF317DWB Tappan/gas Range
Tappan TGF317DWC Tappan/range
Tappan TGF317DWD Tappan/range
Tappan TGF317DWE Tappan/range
Tappan TGF317DWF GAS RANGE
Tappan TGF317ESA Tappan/range
Tappan TGF317ESB Tappan/range
Tappan TGF317ESC Tappan/range
Tappan TGF317ESD Tappan/range
Tappan TGF317ESE GAS RANGE
Tappan TGF317ESF TAPPAN/RANGE
Tappan TGF320DUA Tappan/gas Range
Tappan TGF320DWA Tappan/gas Range
Tappan TGF320DWB Tappan/range
Tappan TGF320DWC Tappan/range
Tappan TGF324BHDD Tappan/gas Range
Frigidaire TGF324BHWA
Frigidaire TGF324BHWB
Tappan TGF324BHWC Tappan/range
Tappan TGF324BHWD Tappan/gas Range
Tappan TGF324BHWE Tappan/gas Range
Tappan TGF324WHSA GAS RANGE
Tappan TGF324WHSB GAS RANGE
Tappan TGF324WHSC GAS RANGE
Tappan TGF324WHSD Tappan/gas Range
Tappan TGF326WHSD Tappan/gas Range
Tappan TGF326WHSE Tappan/gas Range
Tappan TGF326WHTD Tappan/gas Range
Tappan TGF326WHTE Tappan/gas Range
Tappan TGF328GSA GAS RANGE
Tappan TGF328GSB GAS RANGE
Tappan TGF328GSC GAS RANGE
Tappan TGF328GSD GAS RANGE
Tappan TGF328GSE GAS RANGE
Tappan TGF328GSG GAS RANGE
Tappan TGF328GSH GAS RANGE
Frigidaire TGF330WCDA Tap(v1) / Gas Range
Frigidaire TGF330WCDB Tap(v1) / Gas Range
Frigidaire TGF330WCDC Tap(v1) / Gas Range
Frigidaire TGF330WCDD Tap(v1) / Gas Range
Frigidaire TGF330WCDE Tap(v1) / Gas Range
Frigidaire TGF330WCWA Tap(v2) / Gas Range
Frigidaire TGF330WCWB Tap(v2) / Gas Range
Frigidaire TGF330WCWC Tap(v2) / Gas Range
Frigidaire TGF330WCWD Tap(v2) / Gas Range
Frigidaire TGF330WCWE Tap(v2) / Gas Range
Frigidaire TGF331SCDA Tap(v1) / Gas Range
Frigidaire TGF331SCDB Tap(v1) / Gas Range
Frigidaire TGF331SCDC Tap(v1) / Gas Range
Frigidaire TGF331SCWA Tap(v2) / Gas Range
Frigidaire TGF331SCWB Tap(v2) / Gas Range
Frigidaire TGF331SCWC Tap(v2) / Gas Range
Frigidaire TGF332BCDA Tap(v1) / Gas Range
Frigidaire TGF332BCDB Tap(v1) / Gas Range
Frigidaire TGF332BCDC Tap(v1) / Gas Range
Frigidaire TGF332BCDD Tap(v1) / Gas Range
Frigidaire TGF332BCDE Tap(v1) / Gas Range
Frigidaire TGF332BCWA Tap(v2) / Gas Range
Frigidaire TGF332BCWB Tap(v2) / Gas Range
Frigidaire TGF332BCWC Tap(v2) / Gas Range
Frigidaire TGF332BCWD Tap(v2) / Gas Range
Frigidaire TGF332BCWE Tap(v2) / Gas Range
Frigidaire TGF334BCDA Tap(v1) / Gas Range
Frigidaire TGF334BCDB Tap(v1) / Gas Range
Frigidaire TGF334BCDC Tap(v1) / Gas Range
Frigidaire TGF334BCDD Tap(v2) / Gas Range
Frigidaire TGF334BCDE Tap(v1) / Gas Range
Frigidaire TGF334BCDF Tap(v1) / Gas Range
Frigidaire TGF334BCDG Tap(v1) / Gas Range
Frigidaire TGF334BCDH Tap(v1) / Gas Range
Frigidaire TGF334BCWA Tap(v2) / Gas Range
Frigidaire TGF334BCWB Tap(v2) / Gas Range
Frigidaire TGF334BCWC Tap(v3) / Gas Range
Frigidaire TGF334BCWD Tap(v4) / Gas Range
Frigidaire TGF334BCWE Tap(v2) / Gas Range
Frigidaire TGF334BCWF Tap(v2) / Gas Range
Frigidaire TGF334BCWG Tap(v2) / Gas Range
Frigidaire TGF334BCWH Tap(v2) / Gas Range
Frigidaire TGF334WFSA Tap(v0) / Gas Range
Frigidaire TGF334WFSB Tap(v0) / Gas Range
Frigidaire TGF334WFSC Tap(v0) / Gas Range
Frigidaire TGF334WFSD Tap(v0) / Range
Frigidaire TGF335BCDA Tap(v1) / Gas Range
Frigidaire TGF335BCDB Tap(v1) / Gas Range
Frigidaire TGF335BCDC Tap(v1) / Gas Range
Frigidaire TGF335BCDD Tap(v1) / Gas Range
Frigidaire TGF335BCDE Tap(v1) / Gas Range
Frigidaire TGF335BCWA Tap(v2) / Gas Range
Frigidaire TGF335BCWB Tap(v2) / Gas Range
Frigidaire TGF335BCWC Tap(v2) / Gas Range
  #2 (permalink)
Old 06-23-2009, 05:17 AM
Senior Expert
APP Volunteer
kayakcrzy will become famous soon enough
Default
replace the coils on the gas valve. the secondary coil is not energizing. replace both coils. it is a cheap and easy fix. tom
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Gas dryer heat won't stay on daveymatt00 Dryer Repair 0 11-24-2009 10:45 AM
gas dryer heat does not stay on lildaddy02 Dryer Repair 0 11-08-2009 08:05 PM
Heat will not stay on owb520 Dryer Repair 2 08-17-2008 01:39 PM
Heat will not stay on owb520 Dryer Repair 4 08-16-2008 03:22 PM
Heat wont stay on MarkReinertson Dryer Repair 1 01-04-2008 01:36 PM
