Discuss
Gas dryer won't heat and timer not working
 in
Dryer Repair
I have a Gas dryer that won't heat and timer not working. It's getting the proper voltage....please
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Gas dryer won't heat and timer not working
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 12-27-2007, 06:45 PM
mark55 mark55 is offline
Junior Member
mark55 is on a distinguished road
Default Gas dryer won't heat and timer not working
Model Number: FDG8977EW0   Brand: Frigidaire   Age: 5 - 10 years
I have a Gas dryer that won't heat and timer not working. It's getting the proper voltage....please help the clothes are piling up!! Thanks!! Mark
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 12-28-2007, 05:51 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Why do you think the timer is not working?
__________________
Professional appliance repair services in Orange County, California.
  #3 (permalink)
Old 12-28-2007, 05:54 PM
Junior Member
Default
I believe the timer is not working because dial does not move and dryer does not turn off...
  #4 (permalink)
Old 12-30-2007, 06:46 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
The first thing I would check is continuity between the timer terminals "B" and "C", and "B" and "A" when the timer is "on".
Remove the power from the dryer. Remove the wire from the timer terminal "B" and check continuity. Both readings suppose to be about zero.
If any one is open - replace the timer.
- The part number for the timer is AP2106034
- Here are the break down diagrams for the Frigidaire dryer Model FDG8977EW0
Happy New year!
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dryer Timer Wire problem deleriousone Dryer Repair 17 08-06-2008 01:21 PM
electric dryer won't heat and timer not moving chefbeav Dryer Repair 1 12-27-2007 02:18 PM
Gas Dryer Runs but Heat Stops Working terrib Dryer Repair 1 12-26-2007 03:37 PM
Dryer doesnt heat but runs, timer isnt working either bridget Dryer Repair 0 11-03-2007 11:37 AM
Maytag Dryer timer won't turn off dugclark Dryer Repair 3 10-22-2007 02:15 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
