| » Some of the display lights not working |
Model Number: MC8000AYW Brand: Maytag Age: 5 - 10 years
My dryer seems to be working fine, exlcuding the display lights on the far left side of the control panel. They do not light up at all. These are the lights for time dry, sensor dry, wrinkle release, air fluff, and the heat levels. All other lights work fine. The dry commands seem to be getting sent to the logic board because the dryer still runs when I make a selection; I just can't tell what type of cycle/heat level I am selecting. I re-seated the cables from the control panel/membrane to the logic board to be safe. Is the issue with the control panel/membrane or is it the logic board? Or simply a bad cable?
Ads By Google Related Models Last edited by Amygirl75 : 12-09-2011 at 10:06 AM. |
Quote:
Since you've checked the harnesses, and everything works except the lights, you'll need to replace the control console, Part number: AP4039020 The control console contains the LED lights and circuitry for the lights to operate. Good Luck,
__________________
Thanks for allowing AppliancePartsPros.com to assist you, Joe M. APP TEAM Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
Amygirl,
Thanks, we try our best, You'll be even happier once you get the control panel replaced. Thanks,
__________________
| Display Modes | |
| Display Temperature Lights are out. | rrebowe@cox.net | Oven Repair (including Ranges and Cooktops) | 0 | 12-12-2010 07:38 AM |
| Top Oven out no lights on display | neal123 | Oven Repair (including Ranges and Cooktops) | 0 | 11-29-2010 10:00 AM |
| All display lights lit up on oven | sunsetquest | Oven Repair (including Ranges and Cooktops) | 0 | 11-11-2010 05:22 PM |
| Jenn Air Oven - all lights on display out | dick saunders | Oven Repair (including Ranges and Cooktops) | 0 | 02-17-2010 06:42 PM |
| Display is not working but the lights and fan are running | mlust | Oven Repair (including Ranges and Cooktops) | 1 | 03-31-2009 08:59 AM |
