muscle car
#1 Posted : Saturday, June 20, 2009 7:05:10 PM(UTC)
muscle car
I have trouble with the dryer not starting. This has been going on for about a year. I had a service man out to confirm what i thought the problem was. He also thought the control board.We have tried a few gimmicks and the dryer continued working. Now is the time to fix it. My problem is i don't know how to get to the control module. Do i need to take the back then the top off or what is the procedure. Any help is appreciated
sidfink43
#2 Posted : Sunday, June 21, 2009 2:46:17 PM(UTC)
sidfink43
It's a pretty easy job. Take the cover off by removing the screws in the back.
Here is the service manual which will guide you through it.
https://secured.whirlpoo...ILE/Duet%20Job%20Aid.pdf
Good luck, let us know how it turns out, and if a new control board does not fix it post a detailed description of the problem and let's see what else we can come up with.
sidfink43
#3 Posted : Sunday, June 21, 2009 2:59:48 PM(UTC)
sidfink43
Oops
Ok, this would probably work a lot better if I were to post the dryer manual and not the washer one.
https://secured.whirlpoo...64beaa/$FILE/Duetdry.pdf
Sorry, it's been a long day. Hope this helps (well it will help more than the washer manual)
muscle car
#4 Posted : Sunday, June 21, 2009 3:29:31 PM(UTC)
muscle car
Thank you for the manual/ I hope i don't have any extra parts when finished.:)
muscle car
#5 Posted : Thursday, July 9, 2009 8:49:00 PM(UTC)
muscle car
I replaced the control board. It seems to be working better but it is still not right. If i leave power to the dryer on for a while i have to turn off or unplug the dryer then plug it back in and then it will work fine. If the power is left on i can see all the lights on the console board seem to be faintly lit and the dryer will not start until i unplug it. I think we had a lightning strike close by a year ago and that is when it started having problems I now have it plugged in to a surge protector.
sidfink43
#6 Posted : Friday, July 10, 2009 6:18:15 AM(UTC)
sidfink43
Well, sorry that did not fix it.
A lightening strike causes all sorts of problems because of the current that is induced in wiring. A strike near our house last month induced current in the TV cable which fried a DVD player. Go figure!
I would start by thorughtly examining the wiring, and if nothing is found replacing the power cord, not likely a problem but an inexpensive thing to rule out. After that you may be looking at replacing the wiring harness, but that is purely speculative.
Sorry I cannot be more helpful, but lightening and appliances just do not do well together.
Let us know if you find a solution, or need some more ideas.
Whirlpool Duet MDL# WWF8400TW02 New Drain Pump (Washer Repair)
by 1Oskydoodle! 3/30/2024 10:30:29 AM(UTC)
Whirlpool Duet Washer - Possible Faulty Fill Valve (Washer Repair)
by Guest 2/2/2024 4:18:21 PM(UTC)
Whirlpool Duet front load washer model WFW8300SW02 (Washer Repair)
by Guest 12/4/2023 8:39:10 AM(UTC)
Whirlpool Duet electric dryer model WED8300SW1 (Dryer Repair)
by Guest 9/9/2023 9:26:30 AM(UTC)
Whirlpool Duet NG Dryer gas smell when off and open door (Dryer Repair)
by Guest 5/16/2023 4:02:36 AM(UTC)
Whirlpool Duet Electric dryer - no heat (Dryer Repair)
by ShawnDS24 2/25/2023 9:08:24 AM(UTC)
Whirlpool Duet dryer WGD9400 knob Removal (Washer Repair)
by Guest 1/1/2023 8:41:47 AM(UTC)
Whirlpool duet clothes washer (Washer Repair)
by DThiessen 9/28/2022 10:08:52 AM(UTC)
Whirlpool Duet YWED7500VW2 (Dryer Repair)
by Guest 6/14/2022 11:19:46 AM(UTC)
Whirlpool Duet intermittent spinning (Dryer Repair)
by wadeburt 5/17/2022 6:31:21 AM(UTC)
Whirlpool Duet F06 error -- seeking input (Washer Repair)
by TexPat60 2/21/2022 8:25:46 PM(UTC)
Whirlpool Duet ghw9300pw4 has power but no start (Washer Repair)
by 5150 2/18/2022 7:16:37 PM(UTC)
Whirlpool duet washer not draining (Washer Repair)
by Guest 2/16/2022 8:40:23 AM(UTC)
Whirlpool Duet Dryer Drum turning difficulty (Dryer Repair)
by DWMalcolm 2/6/2022 12:41:34 PM(UTC)
Whirlpool duet dryer issue (Dryer Repair)
by Wes13 12/15/2021 3:54:09 PM(UTC)
