| » My Dryer Won't Heat |
Model Number: LER4634JQ1 Brand: Whirlpool Age: 1 - 5 years
I checked my circuit breakers and they are fine. The 3-prong outlet works and is fine. My dryer runs and runs and never gets hot and never turns off. It has to be shut off manually. I have replaced the following
and cleaned out all lint from everywhere. Am I missing something? Please help. AP3094244 (279816) - Thermal cut-off for dryer heating element 309 degrees (includes high-limit thermostat) AP3132867 (3392519) - Thermal fuse (disposable, one time fuse) AP3131941 (3977767) - Thermostat, fixed AP3094254 (279838) - Dryer heating element AP3131939 (3387134) - Dryer cycling thermostat, L155-25 Ads By Google Related Models |
Try starting the dryer on the time cycle around let,s say the 30 min mark. While running hold the timer knob and press in down or up holding it there for a few minutes open the door a check to see if there is heat . If so you will need a timer. good luck.
__________________
Mell you check almost everthing on the dryer,but this going to sound funny but the trouble could be in the motor.The motor has a centrifugal switch on it.This switch consists of one single-pole double-throw[spdt]and a single-pole single-throw switch.What could be happening is the [spst] switch may be opened.Normally when the motor is up to speed,the[spst]switch closes a separate power circuit to the dryer heating element. To check this there should be continuity between terminals 4 and 5 and between 2 and 3. ..GOOD LUCK.
__________________
OH YOU MEAN READINGS FOR THE CENTRIFUGAL SWITCH infinity would be good...lol NOW if your testing the motor protector in the centrifugal switch[2 to 4.5 ohms lets say +/-10% across terminals1 and 4 does this sound ok...
__________________
You will need to jam a flat bladed screwdriver to activate the centrifical switch. Jam it between the housing and the black plastic ring in the motor.Then test the switch pins 1-2, should be a red dot for both on the switch.
We all depend on meter data for these electrical items, without it we are left helpless.
__________________
- Last edited by richappy : 12-29-2007 at 01:19 PM. |
| Display Modes | |
| Roper (Gas) Dryer heats up then heat goes off (still running, no heat) | jtdesignsca | Dryer Repair | 3 | 01-17-2013 12:06 PM |
| Clothes dryer runs, but doest not heat (Dryer no heat | yzhong | Dryer Repair | 5 | 10-29-2009 04:54 PM |
| Dryer will not heat. It tumbles and cycles but it will not emit any heat. | agentsmith0505 | Dryer Repair | 0 | 10-14-2009 09:44 AM |
| Gas Dryer tumbles but won't heat. Timer does not move when dryer is started. | NEAL AMES | Dryer Repair | 1 | 01-02-2009 06:40 PM |
| Dryer will not heat during timed drying; will heat for short time while auto drying | mg13nj | Dryer Repair | 11 | 11-11-2008 03:50 PM |
