| » Dryer has humming noise when start button is push |
Model Number: ler4634eqo Brand: Whirlpool Age: More than 10 years
My dryer makes a humming noise when start button is push. This is the first time we had any problems with dryer.
I am assuming that it hums but will not start and that the humming is coming from the motor.
First, mannually turn the drum to make certain it is not jammed or hung up so that it does not turn. If the drum turns, try this test. With another person, open the door and have that person depress the door switch. Then push the start button and manually turn the drum. If it starts up, then the likely culprit is the motor which will have to be replaced. Good luck, let us know what you find out.
__________________
| Display Modes | |
| whirlpol dryer won't start-just hums when I push the start button | bdubois | Dryer Repair | 27 | 02-18-2010 07:36 PM |
| Electric dryer makes the end of cycle sound when i push the start button | candy2785 | Dryer Repair | 1 | 01-08-2010 02:11 AM |
| Kenmore Dryer won't start unless PTS (push to start) button depressed and held | trp | Dryer Repair | 1 | 06-07-2009 06:13 AM |
| Washer Makes Strange Noise When I Push Start Button | Kelli Huntsman | Washer Repair | 0 | 01-05-2009 09:28 AM |
| Stops when push to start button is released | Burgbrd | Dryer Repair | 4 | 01-02-2008 07:48 PM |
