Discuss
Whirpool Dryer has heat but takes forever to dry
 in
Dryer Repair
I recently replaced the heating element but it still is taking forever to dry. I just started using a voltage
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Whirpool Dryer has heat but takes forever to dry
  By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 06-19-2009, 02:28 PM
Junior Member
rcooks87 is on a distinguished road
Default Whirpool Dryer has heat but takes forever to dry
Model Number: LEC5000PQ0   Brand: Whirlpool   Age: 1 - 5 years
I recently replaced the heating element but it still is taking forever to dry. I just started using a voltage meter and I think I'm using it right. Element checks out as good. I think I read the cycling thermostat could be the problem next. I tried checking it...the two terminals where the red wires attach show the piece is good. But if I touch the two terminals where the smaller purple wires connect to...it shows bad. Is this the problem or am I just not checking it right? Thank for your help.
Related Models
Whirlpool LEC5000PQ0 29" ELECTRIC DRYER
Whirlpool LEC5000PQ1 29" ELECTRIC DRYER
Amana LEC50AW DRYER- ELE
Amana LEC60AW DRYER- ELE
Whirlpool LEC6646AN0 ELECTRIC DRYER
Whirlpool LEC6646AN1 ELECTRIC DRYER
Whirlpool LEC6646AN2 ELECTRIC DRYER
Whirlpool LEC6646AQ0 Residential Dryer
Whirlpool LEC6646AQ1 ELECTRIC DRYER
Whirlpool LEC6646AQ2 ELECTRIC DRYER
Whirlpool LEC6646AW0 Residential Dryer
Whirlpool LEC6646AW1 ELECTRIC DRYER
Whirlpool LEC6646AW2 ELECTRIC DRYER
Whirlpool LEC6646AZ1 ELECTRIC DRYER
Whirlpool LEC6646AZ2 ELECTRIC DRYER
Whirlpool LEC6646AZO ELECTRIC DRYER
Whirlpool LEC6848AN0 ELECTRIC DRYER
Whirlpool LEC6848AN1 ELECTRIC DRYER
Whirlpool LEC6848AN2 ELECTRIC DRYER
Whirlpool LEC6848AN3 ELECTRIC DRYER
Whirlpool LEC6848AQ0 Residential Dryer
Whirlpool LEC6848AQ1 ELECTRIC DRYER
Whirlpool LEC6848AQ2 ELECTRIC DRYER
Whirlpool LEC6848AQ3 ELECTRIC DRYER
Whirlpool LEC6848AW0 ELECTRIC DRYER
Whirlpool LEC6848AW1 TECH SHEET - DRYER - REVISION REL.
Whirlpool LEC6848AW2 ELECTRIC DRYER
Whirlpool LEC6848AW3 ELECTRIC DRYER
Whirlpool LEC6848AZ1 ELECTRIC DRYER
Whirlpool LEC6848AZ2 ELECTRIC DRYER
Whirlpool LEC6848AZ3 ELECTRIC DRYER
Whirlpool LEC6858AQ3 ELECTRIC DRYER
Whirlpool LEC7646DQ0 ELECTRIC DRYER
Whirlpool LEC7646DQ1 ELECTRIC DRYER
Whirlpool LEC7646DZ0 ELECTRIC DRYER
Whirlpool LEC7646DZ1 ELECTRIC DRYER
Whirlpool LEC7848DQ0 ELECTRIC DRYER
Whirlpool LEC7848DQ1 ELECTRIC DRYER
Whirlpool LEC7848DZ0 ELECTRIC DRYER
Whirlpool LEC7848DZ1 ELECTRIC DRYER
Whirlpool LEC7858AN0 ELECTRIC DRYER
Whirlpool LEC7858AN1 ELECTRIC DRYER
Whirlpool LEC7858AN2 ELECTRIC DRYER
Whirlpool LEC7858AQ0 ELECTRIC DRYER
Whirlpool LEC7858AQ1 ELECTRIC DRYER
Whirlpool LEC7858AQ2 ELECTRIC DRYER
Whirlpool LEC7858AW0 Residential Dryer
Whirlpool LEC7858AW1 ELECTRIC DRYER
Whirlpool LEC7858AW2 ELECTRIC DRYER
Whirlpool LEC7858AZ0 ELECTRIC DRYER
Whirlpool LEC7858AZ1 ELECTRIC DRYER
Whirlpool LEC7858AZ2 ELECTRIC DRYER
Amana LEC80AW DRYER- ELE
Whirlpool LEC8858DQ0 ELECTRIC DRYER
Whirlpool LEC8858DQ1 ELECTRIC DRYER
Whirlpool LEC8858DZ0 ELECTRIC DRYER
Whirlpool LEC8858DZ1 ELECTRIC DRYER
Whirlpool LEC8858EQ0 ELECTRIC DRYER
Whirlpool LEC8858EQ1 DRYERS
Whirlpool LEC8858EQ2 ELECTRIC DRYER
Whirlpool LEC8858EZ0 ELECTRIC DRYER
Whirlpool LEC8858EZ1 DRYERS
Whirlpool LEC8858EZ2 ELECTRIC DRYER
Whirlpool LEC9000PW0 29" ELECTRIC DRYER
Whirlpool LEC9000PW1 29" ELECTRIC DRYER
Amana LEC90AW DRYER- ELE
Frigidaire LECR23EFE0 Frigidaire/refrigerator
Frigidaire LECR23EFE1 REFRIGERATOR
Frigidaire LECR23EFE2 REFRIGERATOR
Frigidaire LECR23EFE3 REFRIGERATOR
Amana LED20AW DRYER- ELE
Amana LED250 WASHER-TOP LOADING
Amana LED250 DRYER- ELE
Amana LED302 DRYER- ELE
Amana LED302 WASHER-TOP LOADING
Amana LED32AW DRYER- ELE
Amana LED450 WASHER-TOP LOADING
Amana LED450 DRYER- ELE
Amana LED502 DRYER- ELE
Amana LED57AW DRYER- ELE
Amana LED65AW DRYER- ELE
Amana LED850 WASHER-TOP LOADING
Amana LED850 DRYER- ELE
Amana LED902 DRYER- ELE
Amana LED950 WASHER-TOP LOADING
Amana LED950 DRYER- ELE
Frigidaire LEDB400FEE0 Frigidaire/dishwasher
Frigidaire LEDB500FEE0 Frigidaire Elements/dishwasher
Whirlpool LEE9848BQ0 ELECTRIC DRYER
Whirlpool LEE9848BQ1 ELECTRIC DRYER
Whirlpool LEE9848BQ2 ELECTRIC DRYER
Whirlpool LEE9848BZ0 ELECTRIC DRYER
Whirlpool LEE9848BZ1 ELECTRIC DRYER
Whirlpool LEE9848BZ2 ELECTRIC DRYER
Frigidaire LEEB30S9FEA Frigidaire/wall Oven
Frigidaire LEEB30T9FEA Frigidaire/wall Oven
Frigidaire LEEC30S9FEA Frigidaire/cooktop
Frigidaire LEEC36S9FEA Frigidaire/cooktop
Frigidaire LEEFM389FEA Frigidaire/electric Range
Frigidaire LEEFM389FEB Frigidaire/electric Range
Frigidaire LEEFM389FEF ELECTRIC RANGE
Whirlpool LEG8858JZ0 ELECTRIC DRYER
Frigidaire LEGC30S9FEA Frigidaire/gas Cooktop
Frigidaire LEGC36S9FEA Frigidaire/gas Cooktop
Frigidaire LEGFM389FEA Frigidaire/gas Range
Frigidaire LEH1642DS0 Frigidaire/laundry Center
Whirlpool LEL7646EQ0 DRYER
Whirlpool LEL7646EQ1 DRYERS
Whirlpool LEL8858DQ0 ELECTRIC DRYER
Whirlpool LEL8858DZ0 ELECTRIC DRYER
Whirlpool LEL8858EQ0 DRYER
Whirlpool LEL8858EQ1 DRYERS
Whirlpool LEL8858EQ2 ELECTRIC DRYER
General Electric LEM045H01 Electric range
General Electric LEM045H02 Counter top microwave
General Electric LEM045H03 Counter top microwave
General Electric LEM045J01 Counter top microwave
  #2 (permalink)
Old 06-19-2009, 06:13 PM
Member
Eddie365 is on a distinguished road
Default
HI. First you should check for air flow.
make sure anough air is being discharge if not you vent house has to be plug up.
  #3 (permalink)
Old 06-19-2009, 06:57 PM
Senior Member
applianceman is on a distinguished road
Default
The operating thermostat can be bad, but I agree with Eddie the dryer vent is the most likely cause for this problem. Make sure there is good airflow all the way outside. Clothes Dryer Repair Guide
  #4 (permalink)
Old 06-20-2009, 03:04 AM
Junior Member
Default dryer airflow checked
I pulled the dryer vent off the wall and ran a cycle venting inside and it is no better.
  #5 (permalink)
Old 06-20-2009, 03:14 AM
Junior Member
Default operating thermostat
but, when I check the operating thermostat with a volt meter it shows its good. Am I doing something wrong with the voltage meter?
  #6 (permalink)
Old 06-20-2009, 04:21 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
Replacement parts for WHIRLPOOL LEC5000PQ0 | AppliancePartsPros.com
Here is the wiring diagram
https://www.servicematters.com/docs/...%208528187.pdf
As you know you need heat and air flow for good drying.
When you had the unit off the vent did you check that the unit has both.
Does changing the temp setting do anything?
If not you have a temp regulation problem re: thermostat etc.
Air flow can be drastically reduced if:
1. Blower wheel is clogged with lint
2. Filter screen has a coating caused by fabric softener
3. Sometimes the blower wheel thread can strip
4. You are actually sucking the air past the heating coils and through the drum so if the drum seals are leaking you pull unheated air into the drum. Usually this will cause the temp fuse on the heater to blow because the operating thermostat on the blower sees a lower temp and causes the unit to overheat.
On the meter usage see below.
Your operating thermostat has an internal heater so with the unit unplugged and at least one side of the device you are trying to measure disconnected.
The contacts should read 0 ohms, use your most sensitive scale.
The internal heater should measure 7,000 ohms (see the wiring diagram).
METER USAGE
__________________
  #7 (permalink)
Old 06-20-2009, 09:34 AM
Junior Member
Default whirlpool dryer woes
thank you for all your ideas. I can see you have really spent some time on this. I am at my wits end. I have vacumed every crack and cranny. Perhaps this model is just a lemon and takes 90 minutes to dry. I'm not clear why the thermostat checks out fine, the element checks fine. I took the venting out of the wall. I'm at a loss. You would expect a little less aggravation from a three year old machine. Any last thoughts anyone???
  #8 (permalink)
Old 06-20-2009, 09:42 AM
Senior Member
Default
90 mins doesn’t seem that bad is your washer spinning out the clothes good? I mean they should be dry in 60-80 but 90 isn’t terrible. Make sure you are using the proper spin speed on the washer.
  #9 (permalink)
Old 06-20-2009, 11:09 AM
Junior Member
Default still not working
yes washer is doing its thing clothes are coming out of washer right. I just followed up on an earlier suggestion of running a load through the low heat cycle and seeing if there was a difference. No difference...clothes came out exactly the same on high heat or low heat...damp...It takes about two cycles either way to dry a load right...sometimes 3 if its a big load.
  #10 (permalink)
Old 06-20-2009, 05:09 PM
Junior Member
Default Operating Thermostat
is an operating thermostat the same as the cycling thermostat and that part contains the internal heater?
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Oven takes forever to heat lynap Oven Repair (including Ranges and Cooktops) 4 12-03-2012 04:48 PM
Oven takes forever to heat up sarahskennedy Oven Repair (including Ranges and Cooktops) 0 02-08-2010 05:46 AM
Oven takes forever to heat up even to 300 degrees MacMrmoe Oven Repair (including Ranges and Cooktops) 0 11-12-2009 03:08 PM
oven takes forever to heat up nitrodog Oven Repair (including Ranges and Cooktops) 0 10-31-2007 03:05 PM
Oven takes forever to heat up Jeff N. Oven Repair (including Ranges and Cooktops) 3 10-10-2007 02:36 PM
