| » Whirpool Dryer has heat but takes forever to dry |
I have the same issues with my whirlpool dryer. I have to put it on two cycles to dry. ( my washer is great) I am going to check the seals to make sure it's not tripping with cooler air coming through. Next is to replace that cycling/operating thermostat I guess.
I went ahead and ordered the thermostat...Not sure about the seal deal...it seemed a little out of my league. I'm hoping this is it...otherwise, I guess its that and I will have to figure it out. But for a three, four year old dryer I wouldn't expect the seals to go and I would expect an electronic issue. We shall see. I will let you know if the fix works as I should be getting the part by Thursday.
Quote:
I went downstairs to my dryer after reading this and posting. I took off the lint catcher from the inside of the dryer, (3 screws) I cleaned the whole thing, after I unplugged the sensor wires, they were so covered in thick lint. I took the sensors off cleaned those( they were gross) and replaced everything, it's working just fine now. It used to take 2, 60 minute timed cycle drys to dry my clothes. I set it on normal with med heat and let the sensors take over...it dried a full load perfectly. Go figure. |
r4-nintendo.com have the best array of M3 real cards, R4 ds cards, R4 dsi cards and the NEW Acekards 2 downloads we hope you take pleasure in using this site whilst getting only the best for your DS!
__________________
http://www.r4-para-ds.es |
r4-card.com have the hottest selection of R4 DS cards, R4 DSi cards, M3 real cards, and the NEW Acekard 2 downloads. We hope you benefit greatly from using this site whilst getting truly the easiest media enhancers you could ever imagine having for your DS console!
__________________
| Display Modes | |
| LG dishwasher takes forever to finish cycle | Pat2622 | Dishwasher Repair | 2 | 02-24-2009 04:24 PM |
| Oven takes forever to heat | lynap | Oven Repair (including Ranges and Cooktops) | 3 | 01-26-2009 11:55 AM |
| Water filling tub for rinse cycle takes forever | Cheryl B | Washer Repair | 4 | 02-15-2008 01:38 PM |
| oven takes forever to heat up | nitrodog | Oven Repair (including Ranges and Cooktops) | 0 | 10-31-2007 04:05 PM |
| Oven takes forever to heat up | Jeff N. | Oven Repair (including Ranges and Cooktops) | 3 | 10-10-2007 03:36 PM |
