Discuss
Dryer doesn't heat up
 in
Dryer Repair
Hello a helpful forum I hope. The heater doesn't kick in and shows no power going to the contacts. (
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Dryer doesn't heat up
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 12-26-2007, 02:39 PM
Bill2007 Bill2007 is offline
Junior Member
Bill2007 is on a distinguished road
Default Dryer doesn't heat up
Model Number: YLEN2000JQ1   Brand: Whirlpool   Age: 5 - 10 years
Hello a helpful forum I hope. The heater doesn't kick in and shows no power going to the contacts. (checked with volt meter) Heating coils look fine and should work. Sensor trouble ? The rest is working fine and now clean too Thanks for any help here. Bill
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 12-26-2007, 03:07 PM
TechnicianBrian TechnicianBrian is offline
Senior Expert
APP Volunteer
TechnicianBrian is on a distinguished road
Default
Veryify first that you have 240vac between the black and red wires at the terminal block. When operating, you should have 240vac when you measure accross the element, but you need to check the thermal cut-out and the high limit thermostat for continuity. Both are attached to the heater housing. If they check OK, check the operating thermostat attached to the blower duct for continuity. Any of these item's will prevent heater operation.
__________________
TechnicianBrian
TechnicianBrian.com
Home Appliance Repair Blog
~ Repair Advice Disclaimer ~
  #3 (permalink)
Old 12-26-2007, 03:21 PM
Junior Member
Default
Helpful and fast The wife has it in use for the moment to get the laundry a bit dryer. So I'll will be the one slowing this down, sorry Brian. Terminal block ? I'm still learning English and have no idea what that would be. There is one censor on the air inlet above the coils, red in and red out to the coils, thought about short it out to see if, but not tried yet. And those are the only two items on the right side air intake. Wire goes from coil further to the front of the machine over the bottom, but as it was filled I didn't tip it over I guess the door switch ? I'm new at this, but here, out in the middle of nowhere (80 miles from any shop) I like to know what I need first Thanks so far, the quick response gives me hope that I can tackle this problem, I 'll report back here asap.(tomorrow) Regards Bill Edit I can supply pictures of my new hobby when needed this should be a picture of it
  #4 (permalink)
Old 01-07-2008, 11:52 AM
Junior Member
Default
Okay, I think it's the thermo cut overheat out thingy placed just above the heating coils that gave up the battle, got a lot of numbers on it though, what number should I use to order a new one ?? And do you guys ship to Canada ?? Thanks for giving me the urge/will to solve this one myself, just talked to a neighbor and he paid $100, just to get a guy out to have a look at his freezer!
  #5 (permalink)
Old 01-07-2008, 03:32 PM
Senior Expert
APP Volunteer
Default
The thermal cut-out makes sense to me. This is the part you are looking for as it includes both thermostats as a kit. I am not sure if AppliancePartsPros ships to Canada or not, but you can take that part number to other part resellers if they don't. Good luck on the repair.
__________________
TechnicianBrian
TechnicianBrian.com
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
dryer won't heat bullas5 Dryer Repair 0 11-23-2007 03:03 PM
Estate Dryer by Whirlpool/Dryer running but no heat tsm11238 Dryer Repair 1 11-06-2007 10:47 AM
My Dryer only has low heat rmoss@footprintscarolina. Dryer Repair 3 10-18-2007 03:09 AM
No Dryer Heat jackd3 Dryer Repair 2 10-06-2007 12:32 PM
Dryer won't heat dwh Dryer Repair 1 07-30-2007 05:35 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
