Discuss
Dryer still won't start, have replaced thermal fuse and thermostat-fix
 in
Dryer Repair
Following instructions read on previous posts to this board, we've replaced the thermal fuse and the thermostat on out
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Dryer still won't start, have replaced thermal fuse and thermostat-fix
  #1 (permalink)
Old 06-15-2009, 04:20 PM
JRHeck JRHeck is offline
Junior Member
JRHeck is on a distinguished road
Default Dryer still won't start, have replaced thermal fuse and thermostat-fix
Model Number: KEYE760WWh1   Brand: Kitchen Aid   Age: More than 10 years
Following instructions read on previous posts to this board, we've replaced the thermal fuse and the thermostat on out 14 yr old Kitchen Aid. Until now, this appliance has never given us any trouble at all.
The dryer stopped running in the middle of the cycle and would not turn back on, the light comes on, the timer works and you can hear a sound from the start button, but even after replacing the above parts, it won't start. My wife said recently that she thought the dryer wasn't heating as well as it used to.
What else do you think I should check; what do you think may be the problem?
Thanks,
Tom
Related Models
Whirlpool KEYE760WWH1
Whirlpool KEYE767WWH0
Whirlpool KEYE770BAL0
Whirlpool KEYE770BAL1
Whirlpool KEYE770BAL2
Whirlpool KEYE770BWH0
Whirlpool KEYE770BWH1
Whirlpool KEYE770BWH2
Whirlpool KEYE777BWH0
Whirlpool KEYE777BWH1
Whirlpool KEYE777BWH2
Whirlpool KEYE778BAL0
Whirlpool KEYE778BAL1
Whirlpool KEYE778BAL2
Whirlpool KEYE800SWH1
Whirlpool KEYE800TAL0
Whirlpool KEYE800THT0
Whirlpool KEYE800TPL0
Whirlpool KEYE800TTO0
Whirlpool KEYE800TWH0
Whirlpool KEYE850VAL0
Whirlpool KEYE850VHT0
Whirlpool KEYE850VPL0
Whirlpool KEYE850VTO0
Whirlpool KEYE850VWH0
Whirlpool KEYE860WAL0
Whirlpool KEYE860WAL1
Whirlpool KEYE860WHT0
Whirlpool KEYE860WPL0
Whirlpool KEYE860WTO0
Whirlpool KEYE860WWH0
Whirlpool KEYE860WWH1
Whirlpool KEYE870BAL0
Whirlpool KEYE870BAL1
Whirlpool KEYE870BWH0
Whirlpool KEYE870BWH1
Whirlpool KEYE900SWH1
Whirlpool KEYE900TAL0
Whirlpool KEYE900THT0
Whirlpool KEYE900TPL0
Whirlpool KEYE900TTO0
Whirlpool KEYE900TWH0
Whirlpool KEYE950VAL0
Whirlpool KEYE950VHT0
Whirlpool KEYE950VPL0
Whirlpool KEYE950VTO0
Whirlpool KEYE950VWH0
Whirlpool KEYE960WAL0
Whirlpool KEYE960WWH0
Whirlpool KEYL400WAL0
Whirlpool KEYL400WWH0
Whirlpool KEYL405WAL0
Whirlpool KEYL405WWH0
Whirlpool KEYL410BAL0
Whirlpool KEYL410BAL1
Whirlpool KEYL410BAL2
Whirlpool KEYL410BWH0
Whirlpool KEYL410BWH1
Whirlpool KEYL410BWH2
Whirlpool KEYL507WWH0
Whirlpool KEYL510BAL0
Whirlpool KEYL510BAL1
Whirlpool KEYL510BAL2
Whirlpool KEYL510BWH0
Whirlpool KEYL510BWH1
Whirlpool KEYL510BWH2
Whirlpool KEYL517BWH0
Whirlpool KEYL517BWH1
Whirlpool KEYL517BWH2
Whirlpool KEYS677EQ0
Whirlpool KEYS677EQ1
Whirlpool KEYS677EQ2
Whirlpool KEYS677EZ0
Whirlpool KEYS677EZ1
Whirlpool KEYS677EZ2
Whirlpool KEYS700EQ0
Whirlpool KEYS700EQ1
Whirlpool KEYS700EZ0
Whirlpool KEYS700EZ1
Whirlpool KEYS700GQ0
Whirlpool KEYS700GT0
Whirlpool KEYS700GZ0
Whirlpool KEYS700JQ0
Whirlpool KEYS700JQ1
Whirlpool KEYS700JT0
Whirlpool KEYS700JT1
Whirlpool KEYS700LQ0
Whirlpool KEYS700LQ1 29"electric Dryer
Whirlpool KEYS700LT0
Whirlpool KEYS700LT1 29"electric Dryer
Whirlpool KEYS710JQ0
Whirlpool KEYS710JQ1
Whirlpool KEYS710LQ0
Whirlpool KEYS710LQ1 29"electric Dryer
Whirlpool KEYS750GQ0
Whirlpool KEYS750GT0
Whirlpool KEYS750GZ0
Whirlpool KEYS750JQ0
Whirlpool KEYS750JQ1
Whirlpool KEYS750JT0
Whirlpool KEYS750JT1
Whirlpool KEYS750LQ0
Whirlpool KEYS750LQ1 29"electric Dryer
Whirlpool KEYS750LQ2 29"electric Dryer
Whirlpool KEYS750LT0
Whirlpool KEYS750LT1 29"electric Dryer
Whirlpool KEYS750LT2 29"electric Dryer
Whirlpool KEYS777EQ0
Whirlpool KEYS777EQ1
Whirlpool KEYS777EZ0
Whirlpool KEYS777EZ1
Whirlpool KEYS850GQ0
Whirlpool KEYS850GT0
Whirlpool KEYS850GZ0
Whirlpool KEYS850JQ0
Whirlpool KEYS850JQ1
Whirlpool KEYS850JT0
Whirlpool KEYS850JT1
Whirlpool KEYS850LE0
Whirlpool KEYS850LE1 29"electric Dryer
  #2 (permalink)
Old 06-15-2009, 06:08 PM
Drags1998 Drags1998 is offline
Senior Expert
APP Volunteer
Drags1998 is on a distinguished road
Default
Check the door switch!!!
__________________
  #3 (permalink)
Old 06-17-2009, 09:52 AM
denman denman is offline
Senior Expert
APP Volunteer
denman will become famous soon enough
Default
Replacement parts for WHIRLPOOL KEYE760WWH1 | AppliancePartsPros.com
Here is a wiring diagram
https://www.servicematters.com/docs/...%203394611.pdf
Which thermal fuse did you replace?
There are two of them one for the heater and one for the motor you want the one on the blower case. Easiest to check this with a meter.
Unplug the unit and check for continuity.
Set the unit to timed dry as this is the simplest set up.
Start circuit path is
NEUTRAL , DOOR SWITCH , TIMER SWITCH 4 T/W , DRIVE MOTOR Start and Main windings , THERMAL FUSE 196 degrees , PUSH TO START contacts R2/R1 , TIMER contacts BU/BK , LINE 1
Note Push TO Start must be pushed to give 0 ohms.
Does the motor buzz when you try top start it?
IF the motor buzzes when you try to start is could be the drum is jammed or the motor is shot.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
dryer overheats, blows thermal fuse netsteeler Dryer Repair 7 06-03-2009 11:08 AM
Whirlpool dryer-thermal fuse keeps blowing needs help Dryer Repair 4 04-13-2009 04:48 PM
thermal fuse art1028 Dryer Repair 2 03-29-2009 12:36 PM
thermal fuse blown, gas dryer crazyman Dryer Repair 1 09-07-2008 03:28 PM
Doesn't start - dryer keeps blowing fuse novas Dryer Repair 0 11-08-2007 02:57 PM
