Discuss
Maytag Neptune Dryer won't start
 in
Dryer Repair
I have a Maytag Neptune Dryer model #MDE6700AYW. It was working fine then when I put a load in it
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Maytag Neptune Dryer won't start
  #1 (permalink)
Old 12-02-2011, 09:03 AM
Junior Member
bakerfarms is on a distinguished road
Default Maytag Neptune Dryer won't start
Brand: Maytag   Age: 5 - 10 years
I have a Maytag Neptune Dryer model #MDE6700AYW. It was working fine then when I put a load in it wouldn't start. It lights up but nobody's home. I can hear a click but still no start. I tried to locate a thermal fuse but unsure of what it looks like on this model. There is no error code but the minutes displayed flashes.
  #2 (permalink)
Old 12-02-2011, 05:13 PM
ApplianceJunk's Avatar
Senior Expert
APP Volunteer
ApplianceJunk is on a distinguished road
Default
I would check the thermo fuse that is located on the blower housing.
__________________
ApplianceJunk.com ~ DIY Appliance Repair Forum
  #3 (permalink)
Old 01-07-2012, 01:41 PM
Junior Member
fromtexas1 is on a distinguished road
Default
Quote:
the forum doesn't work
  #4 (permalink)
Old 01-07-2012, 02:00 PM
Junior Member
Default
My Maytag Neptune dryer MDE6700AYW is only 2 years old. I stopped working in the middle of a run. The clothes were almost dried. I checked the electric outlet to have 120V and 240V normal. I tried different setting including timed only in vain. I then checked error code in the service mode to be 10 (sensor bar detects no wet clothes while in a dry cycle).
I got a service manual 16025911 to take the dryer apart. Here are the checks that I performed:
1. On control board, sensor bars pin4-5 (CN6): open (spec is open)
2. On control board, cycling thermostat pin1-2 (CN6): 12 KOhms (spec ~10KOhms)
3. On exhaust, thermistor: 11KOhms (spec ~10KOhms)
4. On exhaust, thermostat: 0.2Ohms (spec <1 Ohm)
5. On heater box, thermal cut off thermostat: 0.2Ohms (spec <1 Ohm)
6. On heater box, Hi Limit thermostat: 0.2 Ohms (spec < 1 Ohm)
7. On heater box, Heat element: 10.3 Ohms (spec 10 Ohms)
8. Door Switch: good
9. Belt cut-off switch: good
10. Motor Pin4-5 (windings): 2 Ohms (spec 2.0Ohms)
11. Motor Pin1-2 (centrifugal S/W): open (spec open)
Any advise?
Thanks,
fromtexas1
  #5 (permalink)
Old 12-29-2012, 10:32 AM
Junior Member
lidle_pool is on a distinguished road
Default
Any advise?
Thanks,
fromtexas1
I have the same dryer with the same issue, what did you end up doing to solve the issue?
-Paul
  #6 (permalink)
Old 12-29-2012, 08:15 PM
Junior Member
Default
Quote:
-Paul
I have to disconnnect the control board from the front panel and reseat them once in a while to make it going again (once a month deal). It must be a chip malfunction I think. Inside boards are in Korean/Samsung. It's a Samsung in Maytag clothes.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag Neptune does not start Doug123 Washer Repair 2 11-29-2013 01:04 AM
Maytag Neptune Doesnt Start FLORIDALISA Washer Repair 0 11-09-2011 06:12 AM
Maytag Neptune MLE2000AYW/dryer wont start KennyLbreedlove Dryer Repair 1 09-22-2011 03:13 AM
Maytag neptune electric dryer won't start area123 Dryer Repair 11 07-10-2010 06:40 AM
Maytag Neptune Electric Dryer (MDE3000AYW )will not start Eckim Dryer Repair 1 03-02-2009 03:48 PM
