Discuss
Whirlpool Dryer won't start, but hums
 in
Dryer Repair
Dryer makes a humming sound when start button is pushed, but won't start. Door is closed.
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Whirlpool Dryer won't start, but hums
  #1 (permalink)
Old 12-01-2011, 09:16 PM
Junior Member
gmreeves2 is on a distinguished road
Default Whirlpool Dryer won't start, but hums
Brand: Whirlpool   Age: 5 - 10 years
  #2 (permalink)
Old 12-02-2011, 03:07 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
A model number may help others help you.
Try turning the drum by hand. Should turn fairly easily. If not could be the drum is jammed for some reason. You may want to try this on a couple other dryers to get a feel for it.
If it is difficult to turn run your fingers around the back and front of the tub to machine seal. To see if something has jammed between the tub and frame (bra wires are famous for this). Be careful in case the object is something sharp.
If nothing is jammed in there you will have to open it up and find the cause.
If it rotates OK.
This may take 2 people
Open the door
Manually hold the door switch closed
Push the start button and manually rotate the drum in the correct direction.
Watch your knuckles in case it starts up.
If it does start up, odds are high that you need a new motor.
Could also be that the motor is jammed solid with lint and this is preventing the Start/Run centrifugal switch from resetting (the unit is trying to start with out the motor's start winding in circuit.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
whirlpol dryer won't start-just hums when I push the start button bdubois Dryer Repair 28 12-10-2013 05:04 PM
Whirlpool dryer hums when start button pushed Avelaz Dryer Repair 3 07-03-2011 05:23 PM
Dryer hums, won't start spearmint Dryer Repair 4 01-18-2011 08:08 PM
Dryer hums, but won't start mvcampbell8 Dryer Repair 5 05-25-2010 07:28 AM
Dryer hums but doesn't start bolinguist Dryer Repair 0 11-22-2007 04:06 PM
