Discuss
Kenmore dryer will not run
 in
Dryer Repair
We have a dryer that will not run. It started by running, then shutting down. It was able to be
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Kenmore dryer will not run
  #1 (permalink)
Old 06-14-2009, 06:15 PM
Junior Member
Robert G. Dobson is on a distinguished road
Default Kenmore dryer will not run
Model Number: 11060932990   Brand: Kenmore   Age: 5 - 10 years
We have a dryer that will not run. It started by running, then shutting down. It was able to be restarted, however now it will not start at all. The heating element shows 10.5 ohms resistance through the coil and no grounding. TheThermostat, thermal cutoff, and thermal fuse all show continuity and the thermistor shows 9.6 ohms resistance. I did not check the motor as yet. Could it possibly be a bad control on the panel or a bad motor?
Ads By Google
Related Models
Kenmore 11061062000 DRYER
Kenmore 11061064000 DRYER
Kenmore 11061066000 DRYER
Kenmore 1106107400 KENMORE GAS DRYER
Kenmore 1106107401 KENMORE GAS DRYER
Kenmore 1106107500 KENMORE GAS DRYER
Kenmore 1106107501 KENMORE GAS DRYER
Kenmore 1106107502 KENMORE GAS DRYER
Kenmore 1106107700 KENMORE GAS DRYER
Kenmore 1106107701 KENMORE GAS DRYER
Kenmore 1106107710 KENMORE GAS DRYER
Kenmore 1106107800 KENMORE GAS DRYER
Kenmore 1106107801 KENMORE GAS DRYER
Kenmore 1106107803 KENMORE GAS DRYER
Kenmore 11061082000 DRYER
Kenmore 1106108400 KENMORE ELECTRIC DRYER
Kenmore 11061084000 DRYER
Kenmore 1106108401 KENMORE ELECTRIC DRYER
Kenmore 1106108500 KENMORE ELECTRIC DRYER
Kenmore 1106108501 KENMORE ELECTRIC DRYER
Kenmore 11061086000 DRYER
Kenmore 1106108700 KENMORE ELECTRIC DRYER
Kenmore 1106108701 KENMORE ELECTRIC DRYER
Kenmore 1106108710 KENMORE ELECTRIC DRYER
Kenmore 1106108800 KENMORE ELECTRIC DRYER
Kenmore 1106108801 KENMORE ELECTRIC DRYER
Kenmore 1106108802 KENMORE ELECTRIC DRYER
Kenmore 11061092000 DRYER
Kenmore 11062032100 ELECTRIC DRYER
Kenmore 11062036100 ELECTRIC DRYER
Kenmore 11062042100 DRYER
Kenmore 11062052100 DRYER
Kenmore 11062054100 DRYER
Kenmore 11062056100 DRYER
Kenmore 11062062100 DRYER
Kenmore 11062062101 ELECTRIC DRYER
Kenmore 11062062102 ELECTRIC DRYER
Kenmore 11062064100 DRYER
Kenmore 11062064101 ELECTRIC DRYER
Kenmore 11062064102 ELECTRIC DRYER
Kenmore 11062066100 DRYER
Kenmore 11062066101 ELECTRIC DRYER
Kenmore 11062066102 ELECTRIC DRYER
Kenmore 1106207400 KENMORE GAS DRYER
Kenmore 1106207401 KENMORE GAS DRYER
Kenmore 1106207420 KENMORE GAS DRYER
Kenmore 1106207421 KENMORE GAS DRYER
Kenmore 1106207430 KENMORE GAS DRYER
Kenmore 1106207431 KENMORE GAS DRYER
Kenmore 1106207432 KENMORE GAS DRYER
Kenmore 1106207433 KENMORE GAS DRYER
Kenmore 1106207500 KENMORE GAS DRYER
Kenmore 1106207501 KENMORE GAS DRYER
Kenmore 1106207502 KENMORE GAS DRYER
Kenmore 1106207511 KENMORE GAS DRYER
Kenmore 1106207600 KENMORE GAS DRYER
Kenmore 1106207601 KENMORE GAS DRYER
Kenmore 1106207700 KENMORE GAS DRYER
Kenmore 1106207701 KENMORE GAS DRYER
Kenmore 1106207702 KENMORE GAS DRYER
Kenmore 11063012100 ELECTRIC DRYER
Kenmore 11063012101 DRYER
Kenmore 11063012102 ELECTRIC DRYER
Kenmore 11063014100 ELECTRIC DRYER
Kenmore 11063014101 DRYER
Kenmore 11063014102 ELECTRIC DRYER
Kenmore 11063022100 DRYER
Kenmore 11063022101 ELECTRIC DRYER
Kenmore 11063022102 ELECTRIC DRYER
Kenmore 11063024100 DRYER
Kenmore 11063024101 ELECTRIC DRYER
Kenmore 11063024102 ELECTRIC DRYER
Kenmore 11063032100 ELECTRIC DRYER
Kenmore 11063032101 ELECTRIC DRYER
Kenmore 11063032102 ELECTRIC DRYER
Kenmore 11063034100 ELECTRIC DRYER
Kenmore 11063034101 ELECTRIC DRYER
Kenmore 11063034102 ELECTRIC DRYER
Kenmore 11063036100 ELECTRIC DRYER
Kenmore 11063036101 ELECTRIC DRYER
Kenmore 11063036102 ELECTRIC DRYER
Kenmore 11063042100 ELECTRIC DRYER
Kenmore 11063042101 DRYER
Kenmore 11063042102 ELECTRIC DRYER
Kenmore 11063046100 ELECTRIC DRYER
Kenmore 11063046101 DRYER
Kenmore 11063046102 ELECTRIC DRYER
Kenmore 11063052100 DRYER
Kenmore 11063052101 DRYER
Kenmore 11063052102 ELECTRIC DRYER
Kenmore 11063062100 DRYER
Kenmore 11063062101 ELECTRIC DRYER
Kenmore 11063062102 ELECTRIC DRYER
Kenmore 11063064100 DRYER
Kenmore 11063064101 ELECTRIC DRYER
Kenmore 11063064102 ELECTRIC DRYER
Kenmore 11063066100 DRYER
Kenmore 11063066101 ELECTRIC DRYER
Kenmore 11063066102 ELECTRIC DRYER
Kenmore 1106307400 KENMORE GAS DRYER
Kenmore 1106307401 KENMORE GAS DRYER
Kenmore 1106307402 KENMORE GAS DRYER
Kenmore 1106307500 KENMORE GAS DRYER
Kenmore 1106307501 KENMORE GAS DRYER
Kenmore 1106307502 KENMORE GAS DRYER
Kenmore 1106307504 KENMORE GAS DRYER
Kenmore 1106307600 KENMORE GAS DRYER
Kenmore 1106307601 KENMORE GAS DRYER
Kenmore 1106307602 KENMORE GAS DRYER
Kenmore 1106307603 KENMORE GAS DRYER
Kenmore 1106407400 KENMORE GAS DRYER
Kenmore 1106407401 GAS DRYER
Kenmore 1106407500 KENMORE GAS DRYER
Kenmore 1106407501 KENMORE GAS DRYER
Kenmore 1106407502 KENMORE GAS DRYER
Kenmore 1106407540 KENMORE GAS DRYER
Kenmore 1106407700 KENMORE GAS DRYER
Kenmore 1106407701 KENMORE GAS DRYER
Kenmore 1106407702 KENMORE GAS DRYER
Kenmore 1106407740 KENMORE GAS DRYER
  #2 (permalink)
Old 06-15-2009, 05:34 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Sounds like the problem is a bad thermistor. The normal thermistor resistance should be about 10 Kohms at the room temperature.
- The part number for the thermistor is AP3919451
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore gas dryer LLB Dryer Repair 0 06-23-2009 11:20 AM
Kenmore gas dryer sunlake Dryer Repair 1 09-04-2008 06:42 PM
Kenmore HE4 Gas Dryer vzrj35 Dryer Repair 0 08-20-2008 06:38 PM
Kenmore Dryer 1945REZN Dryer Repair 0 02-02-2008 10:13 AM
Kenmore dryer jdman Dryer Repair 3 08-04-2007 07:53 PM
