Discuss
Need advice on what to check: dryer not drying
 in
Dryer Repair
Hi all, I have a Whirlpool LER5636PQ0 that, about 2 months ago, began a distinct decline in drying ability. It
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Need advice on what to check: dryer not drying
  #1 (permalink)
Old 12-01-2011, 06:14 PM
Junior Member
antessima is on a distinguished road
Default Need advice on what to check: dryer not drying
Model Number: LER5636PQ0   Brand: Whirlpool   Age: 5 - 10 years
Hi all,
I have a Whirlpool LER5636PQ0 that, about 2 months ago, began a distinct decline in drying ability. It now consistently takes 2-3 cycles to fully dry a load of clothes. They are dry then, but this is obviously using a lot more electricity than I want to use in the cold months.
My question is, what things should I check to try to find the problem? I'm modestly familiar with multimeters (I really should go out and by one anyway), so I can test for resistance or continuity or voltage levels if necessary. I just don't know where to start The dryer isn't exhibiting any other odd behaviors. I typically use the automatic low-heat drying cycle, but using the timed high-heat cycle didn't produce any different results. I've also already checked and made sure that the exhaust vent was clear of any kind of blockages.
Any thoughts?
Ads By Google
Related Models
Whirlpool LER5636PQ0 29"electric Dryer
Whirlpool LER5636PQ1 29"electric Dryer
Whirlpool LER5636PT0 29"electric Dryer
Whirlpool LER5636PT1 29"electric Dryer
Whirlpool LER5638AN0
Whirlpool LER5638AN1
Whirlpool LER5638AN2
Whirlpool LER5638AN3
Whirlpool LER5638AW0
Whirlpool LER5638AW1
Whirlpool LER5638AW2
Whirlpool LER5638AW3
Whirlpool LER5644AN0
Whirlpool LER5644AN1
Whirlpool LER5644AN2
Whirlpool LER5644AW0
Whirlpool LER5644AW1
Whirlpool LER5644AW2
Whirlpool LER5644EQ0
Whirlpool LER5644EQ1
Whirlpool LER5644EQ2
Whirlpool LER5644EZ0
Whirlpool LER5644EZ1
Whirlpool LER5644EZ2
Whirlpool LER5644JQ0
Whirlpool LER5644JQ1
Whirlpool LER5644JQ2
Whirlpool LER5644JQ3 29"electric Dryer
Whirlpool LER5644JT0
Whirlpool LER5644JT1
Whirlpool LER5644JT2
Whirlpool LER5644JT3 29"electric Dryer
Whirlpool LER5644PQ0 29"electric Dryer
Whirlpool LER5644PQ1 29"electric Dryer
Whirlpool LER5700KQ0
Whirlpool LER5700KQ1
Whirlpool LER5700KT0
Whirlpool LER5700KT1
Whirlpool LER5848EQ0
Whirlpool LER5848EQ1
Whirlpool LER5848EQ2
Whirlpool LER5848EQ3
Whirlpool LER5848EQ4
Whirlpool LER5848EQ5
Whirlpool LER6611LQ0
Whirlpool LER6611LQ1 29"electric Dryer
Whirlpool LER6611PQ0 29" Electric Dryer
Whirlpool LER6620PQ0 29"electric Dryer
Whirlpool LER6620PQ1 29"electric Dryer
Whirlpool LER6620PT0 29"electric Dryer
Whirlpool LER6620PT1 29"electric Dryer
Whirlpool LER6621PQ0 29" Electric Dryer
Whirlpool LER6634BN0
Whirlpool LER6634BN1
Whirlpool LER6634BN2
Whirlpool LER6634BQ0
Whirlpool LER6634BQ1
Whirlpool LER6634BQ2
Whirlpool LER6634BW0
Whirlpool LER6634BW1
Whirlpool LER6634BW2
Whirlpool LER6634DQ0
Whirlpool LER6634DQ1
Whirlpool LER6634DW0
Whirlpool LER6634DW1
Whirlpool LER6634DZ0
Whirlpool LER6634DZ1
Whirlpool LER6636PW0 29" Electric Dryer
Whirlpool LER6636PW1 29" Electric Dryer
Whirlpool LER6638DQ0
Whirlpool LER6638DQ1
Whirlpool LER6638DW0
Whirlpool LER6638DW1
Whirlpool LER6638DZ0
Whirlpool LER6638DZ1
Whirlpool LER6644DQ0
Whirlpool LER6644DQ1
Whirlpool LER6644DZ0
Whirlpool LER6644DZ1
Whirlpool LER6646BN0
Whirlpool LER6646BN1
Whirlpool LER6646BN2
Whirlpool LER6646BW0
Whirlpool LER6646BW1
Whirlpool LER6646BW2
Whirlpool LER6646DN1
Whirlpool LER6646DW1
Whirlpool LER6646PW0 29" Electric Dryer
Whirlpool LER6646PW1 29" Electric Dryer
Whirlpool LER6848AN0
Whirlpool LER6848AN1
Whirlpool LER6848AN2
Whirlpool LER6848AQ2
Whirlpool LER6848AW0
Whirlpool LER6848AW1
Whirlpool LER6848AW2
Whirlpool LER6848AZ2
Whirlpool LER7620KQ0
Whirlpool LER7620KQ1
Whirlpool LER7620KT0
Whirlpool LER7620KT1
Whirlpool LER7620LG0
Whirlpool LER7620LG1 29"electric Dryer
Whirlpool LER7620LQ0
Whirlpool LER7620LW0
Whirlpool LER7620LW1 29"electric Dryer
Whirlpool LER7646AN0
Whirlpool LER7646AN1
Whirlpool LER7646AN2
Whirlpool LER7646AQ0
Whirlpool LER7646AQ1
Whirlpool LER7646AQ2
Whirlpool LER7646AW0
Whirlpool LER7646AW1
Whirlpool LER7646AW2
Whirlpool LER7646AZ0
Whirlpool LER7646AZ1
Whirlpool LER7646AZ2
Whirlpool LER7646DQ0
Whirlpool LER7646DQ1
  #2 (permalink)
Old 12-03-2011, 06:16 AM
ApplianceJunk's Avatar
Senior Expert
APP Volunteer
ApplianceJunk is on a distinguished road
Default
Increased drying times are almost always a sure sign of a air flow problem.
I read that you checked your dryer vent for blockage from lint build up, but one place that is often missed is around the blower housing.
I would take the dryer apart and remove the blower house to check it for lint build up.
__________________
ApplianceJunk.com ~ DIY Appliance Repair Forum
  #3 (permalink)
Old 12-03-2011, 10:48 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
I would try the following. Could be the venting is clear but the exterior louvers are not opening. Also it is one way to totally eliminate the vent system as the cause.
Unplug the unit and disconnect it from the vent system.
Now try a run.
If it now dries OK odds are the vent system needs checking/cleaning.
Be sure to check that the louvers on the outside of the house open correctly.
If you do not want any lint in the house.
Take a pair of pantyhose.
Put one leg into the other and then attach this to the dryer's vent.
Leave enough room so the pantyhose can balloon out like a windsock.
Both the above will let you check the temperature and the air flow.
Note: The above is not recommended for gas dryers due to carbon monoxide concerns.
I would also check your lint screen. Sometimes they get coated with fabric softener residue and need to be washed. In extreme cases even the holes at the back of the drum can get clogged.
Check the seals in the air flow path in the unit especially at the blower.
__________________
  #4 (permalink)
Old 02-19-2012, 05:10 PM
Junior Member
Question
Well, it only took me 2 and a half months, but I finally got around to testing the airflow. First, back about a week or so after I got your responses, I took the entire thing apart and cleaned every shred of lint out of it that I could. There was a noticeable amount in the exhaust blower, lint chute, and hose/vent. I put it all back together and it worked wonderfully for about 3 loads, then started developing some problems drying again. Each time we would run a load, there would be a little bit of lint in the trap, but much, much less than there used to be when it was running well.
Fast forward to today. I finally took the hose off of the vent again, and when I did I saw a lot of lint in both. I put the pantyhose over the end of the hose and let the dryer run. First, the pantyhose barely inflated. The clothes also remained wet at the end of one run, and took a second run to fully dry. There was, again, practically no lint in the trap, but there was a hefty chunk of it on the pantyhose.
When I had this thing taken apart back in December, there was almost no lint anywhere except in the lint chute/exhaust blower. Given the above symptoms and evidence, what do you guys think the odds are that replacing the lint trap--and possibly the chute--will solve this? I'm looking at $47-$113 to buy the replacement parts, which is much less than buying a new dryer but still a substantial amount of cash from which to be departed (especially if it doesn't work and I still have to spend $400+ for the new dryer).
Thanks for any advice you can offer.
  #5 (permalink)
Old 02-22-2012, 05:40 AM
Senior Expert
APP Volunteer
Default
From your descri[ption it does sound like the lint is getting past the lint filter.
Since the lint chute is metal my guess would be a problem with the lint filter.
__________________
  #6 (permalink)
Old 02-22-2012, 11:18 AM
Junior Member
Default
That's sorta what I was thinking too. I will start there (and replace the hose/clean the exhaust vent again) and see if that works.
If anyone else has any other ideas, let me know. Thanks!
  #7 (permalink)
Old 02-23-2012, 03:49 AM
Junior Member
feniko is on a distinguished road
Default
thanks for this is really helpful
be naughty review
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
need some dryer advice for non heating studer6 Dryer Repair 1 04-29-2010 07:29 AM
Dryer repair advice deanbowker Dryer Repair 6 03-17-2010 07:27 PM
Dryer will not heat during timed drying; will heat for short time while auto drying mg13nj Dryer Repair 11 11-11-2008 03:50 PM
Advice on Diagnosing Overheating Dryer please grantmarkham Dryer Repair 6 08-18-2008 12:12 PM
