| » Roper Dryer will not start |
Model Number: RES7745RQ0 Brand: Roper Age: 1 - 5 years
My Roper Dryer will not start, no tumble and no heat. I checked the fuse, and door switch. I checked the start switch and made sure it opened and closed on the blue wires. The continuity looks good. Is there a common problem on this dryer?
In addition to my first post, I tested the motor with 115vdc and it tested ok. I rotated the Timer manually to see if the buzzer would go off and it did not. So if does that mean the Timer may be bad? Is ther any other way to knowif the Timer is bad?
Jump out the thermal fuse, and then plug the unit in and see if it works. Tom ********************************************
| Display Modes | |
| Roper Dryer does not start | Korsch | Dryer Repair | 6 | 03-16-2013 03:46 AM |
| Roper Dryer Won't Start | jfemal | Dryer Repair | 5 | 03-16-2009 01:04 PM |
| Roper Dryer will not start | signsofthetimes | Dryer Repair | 0 | 01-26-2009 05:40 PM |
| Roper Dryer won't start... | deanna08 | Dryer Repair | 1 | 12-18-2008 03:55 PM |
| Roper Dryer wont start | Scott65 | Dryer Repair | 4 | 03-10-2008 07:40 AM |
