fayl
#1 Posted : Sunday, June 14, 2009 6:36:31 AM(UTC)
fayl
how do i replace a felt dryer door gasket. :confused:
sidfink43
#2 Posted : Tuesday, June 16, 2009 12:44:28 PM(UTC)
sidfink43
Boy, this is one of those things that is easy to do, but hard to describe.
The gasket goes underneat the front panel, and then hooks over a plastic cut out piece.
Here is the exploded parts diagram,which may help.
Replacement parts for GE DWSR483EB0WW | AppliancePartsPros.com
To access the front, take out the screws holding the top down, they are found inside the door. The top will lift out, and then you can take of the front by taking out the two screws that hold it. Be sure to disconnect the lid switch.
Hope this helps, its one of those things I have done often enough, but never had to explain to someone who was not there.
Good luck
felt gasket replacment (Dryer Repair)
by fayl 6/14/2009 6:30:02 AM(UTC)
