Discuss
electric Dryer cord rplacement
 in
Dryer Repair
I need step by step instructions on placing a three progg power cord, thus, I have never done this before.
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » electric Dryer cord rplacement
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 12-23-2007, 12:01 PM
nancygail nancygail is offline
Junior Member
nancygail is on a distinguished road
Question electric Dryer cord rplacement
Model Number: DE400.JDW1   Brand: White-Westinghouse   Age: 5 - 10 years
I need step by step instructions on placing a three progg power cord, thus, I have never done this before. Thank you
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 12-25-2007, 02:05 PM
Gene's Avatar
Gene Gene is online now
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Why do you need to replace the power cord?
__________________
Professional appliance repair services in Orange County, California.
  #3 (permalink)
Old 12-25-2007, 06:59 PM
Junior Member
Default
Because someone took off the cord. Thanks for responding
  #4 (permalink)
Old 12-25-2007, 09:01 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Pull the dryer off the wall.
Remove the cover (#8 on the cabinet break down diagram).
You can see now the terminal block (#12 on the cabinet break down diagram) with the three wires attached coming from the inside of the dryer (red, white and black).
The white wire (neutral) should be in the middle.
Remove one nut from each terminal and put the the terminals from the power cord on the terminals on the terminal block. The middle wire (neutral) from the power cord should be attached to the middle terminal on the terminal block.
Screw back on the nuts and tight them as much as possible.
Install the cover back in place and you done.
- The part number for the power cord is AP2615176
- Here are the break down diagrams for the White Westinghouse dryer Model DE400JDW1
Good luck.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Power cord james188 Oven Repair (including Ranges and Cooktops) 1 12-22-2007 09:24 PM
dryer cord wiring jschutter Dryer Repair 0 11-21-2007 05:20 PM
Frigidaire microwave power cord blar Microwave Repair 1 11-14-2007 08:00 PM
replacing an electric cord Mc Glory Dryer Repair 1 10-06-2007 08:07 AM
Electric Dryer too hot jim k Dryer Repair 3 07-25-2007 04:43 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
