Discuss
Dryer won't start, inside light won't come on
 in
Dryer Repair
I was drying a load and realized the dryer had been going a long time. When I checked it, the
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Dryer won't start, inside light won't come on
  #1 (permalink)
Old 06-13-2009, 10:06 AM
Junior Member
StaceyLee is on a distinguished road
Default Dryer won't start, inside light won't come on
Model Number: 86574110   Brand: Kenmore   Age: 1 - 5 years
I was drying a load and realized the dryer had been going a long time. When I checked it, the timer had not moved. I opened the dryer and it was not hot. I closed it and tried to start it and it wouldn't start. The light in the dryer is not working either. I checked the house fuse and it is not blown.
Is there a fuse within the dryer that might be blown? Any ideas?
Thanks.
Related Models
Magic Chef 8660PB SURFACE UNIT- ELE
Magic Chef 8660PV SURFACE UNIT- ELE
Magic Chef 8670PB SURFACE UNIT- ELE
Magic Chef 8670PV SURFACE UNIT- ELE
Magic Chef 8670RB SURFACE UNIT- ELE
Magic Chef 8670RV SURFACE UNIT- ELE
Jenn-Air 86732 MISC / ACCESSORY
Amana 86851 REF - TOP MOUNT
Frigidaire 86851-0A FREEZER
Frigidaire 86851-0B FREEZER
Frigidaire 86851-0D FREEZER
Amana 86855 REF - TOP MOUNT
Amana 86858 REF - TOP MOUNT
Amana 86861 REF - TOP MOUNT
Amana 86861W REF - TOP MOUNT
Amana 86868 REF - TOP MOUNT
Amana 86868L REF - TOP MOUNT
Amana 86871 REF - TOP MOUNT
Amana 86878 REF - TOP MOUNT
Magic Chef 86HA-1 SURFACE UNIT- ELE
Magic Chef 86HK-1 SURFACE UNIT- ELE
Magic Chef 86HN-1 SURFACE UNIT- ELE
Magic Chef 86HS-1 SURFACE UNIT- ELE
Magic Chef 86HY-1 SURFACE UNIT- ELE
Magic Chef 86LA-1 SURFACE UNIT- ELE
Magic Chef 86LK-1 SURFACE UNIT- ELE
Magic Chef 86LN-1 SURFACE UNIT- ELE
Magic Chef 86LS-1 SURFACE UNIT- ELE
Magic Chef 86LW-1 SURFACE UNIT- ELE
Hoover 87
Amana 8700.A MWAVE - FAMILY SIZE (60 HZ)
Magic Chef 8710PA SURFACE UNIT- ELE
Magic Chef 8710PB SURFACE UNIT- ELE
Magic Chef 8710PS SURFACE UNIT- ELE
Magic Chef 8710PW SURFACE UNIT- ELE
Magic Chef 8710VB SURFACE UNIT- ELE
Magic Chef 8710VD SURFACE UNIT- ELE
Magic Chef 8710VS SURFACE UNIT- ELE
Magic Chef 8710VV SURFACE UNIT- ELE
Magic Chef 8720PA SURFACE UNIT- ELE
Magic Chef 8720PS SURFACE UNIT- ELE
Magic Chef 8720PW SURFACE UNIT- ELE
Magic Chef 8720VB SURFACE UNIT- ELE
Magic Chef 8720VD SURFACE UNIT- ELE
Magic Chef 8720VQ SURFACE UNIT- ELE
Magic Chef 8720VS SURFACE UNIT- ELE
Magic Chef 8720VV SURFACE UNIT- ELE
Amana 874.000 RANGE- S/C S/I DDRAFT GAS
Amana 874.001 RANGE- S/C S/I DDRAFT GAS
Amana 874.301 MWAVE - FAMILY SIZE (60 HZ)
Amana 874.302 MWAVE - FAMILY SIZE (60 HZ)
Amana 874.304 MWAVE - FAMILY SIZE (60 HZ)
Amana 874.305 MWAVE - FAMILY SIZE (60 HZ)
Amana 876.A MWAVE - FAMILY SIZE (60 HZ)
Amana 876.B MWAVE - FAMILY SIZE (60 HZ)
Magic Chef 8770RB SURFACE UNIT- ELE
Magic Chef 8770RV SURFACE UNIT- ELE
Jenn-Air 87848 RANGE- F/S STD DDRAFT ELE
Jenn-Air 87849 RANGE- F/S STD DDRAFT ELE
Jenn-Air 87899 MISC / ACCESSORY
Jenn-Air 87904 ELE CARTRIDGE
Jenn-Air 87914 MISC / ACCESSORY
Jenn-Air 87919 MISC / ACCESSORY
Niagra 8795-0 4000 WATT PORTABLE AC GENERATOR
Magic Chef 87LA-1 SURFACE UNIT- ELE
Magic Chef 87LA-1G SURFACE UNIT- ELE
Magic Chef 87LK-1 SURFACE UNIT- ELE
Magic Chef 87LN-1 SURFACE UNIT- ELE
Magic Chef 87LN-1G SURFACE UNIT- ELE
Magic Chef 87LS-1 SURFACE UNIT- ELE
Magic Chef 87LS-1G SURFACE UNIT- ELE
Hoover 88
Amana 880.000 RANGE- S/C S/I DDRAFT GAS
Amana 880.001 RANGE- S/C S/I DDRAFT GAS
Amana 880.002 MWAVE - FAMILY SIZE (60 HZ)
Amana 880.003 RANGE- S/C S/I DDRAFT GAS
Amana 880.004 RANGE- S/C S/I DDRAFT GAS
Amana 880.110 RANGE- S/C S/I DDRAFT GAS
Amana 880.120 RANGE- S/C S/I DDRAFT GAS
Amana 880.130 RANGE- S/C S/I DDRAFT GAS
Amana 880.130*1 LITTON BUILT-IN WALL OVEN
Amana 880.130x1 RANGE- S/C S/I DDRAFT GAS
Frigidaire 88057-7A CHEST FREEZER
Whirlpool 880652124P0 30" ELECTRIC CERAN FREESTANDING RANGE STANDARD CLEAN OVEN
Frigidaire 88157-7A CHEST FREEZER
Frigidaire 88158-7A CHEST FREEZER
Frigidaire 88158A CHEST FREEZER
Frigidaire 88161-0A FREEZER
Frigidaire 88161-0B FREEZER
Frigidaire 88161-0D FREEZER
Jenn-Air 88168 RANGE- F/S STD DDRAFT ELE
Jenn-Air 88169 RANGE- F/S STD DDRAFT ELE
Jenn-Air 88170 RANGE- F/S STD DDRAFT ELE
Jenn-Air 88186 MISC / ACCESSORY
Frigidaire 88258-7A FREEZER
Frigidaire 88258-7B FREEZER
Frigidaire 88269A CHEST FREEZER
Frigidaire 88269B CHEST FREEZER
Jenn-Air 88353 SURFACE UNIT- ELE
Jenn-Air 88353-8 SURFACE UNIT- ELE
Jenn-Air 88368 RANGE- F/S STD DDRAFT ELE
Jenn-Air 88369 RANGE- F/S STD DDRAFT ELE
Jenn-Air 88370 RANGE- F/S STD DDRAFT ELE
Jenn-Air 88371 RANGE- F/S STD DDRAFT ELE
Jenn-Air 88372 RANGE- F/S STD DDRAFT ELE
Whirlpool 885450 ELECTRIC DRYER
Whirlpool 885453 ELECTRIC DRYER
Whirlpool 885455 ELECTRIC DRYER
Whirlpool 885456 ELECTRIC DRYER
Whirlpool 885457 ELECTRIC DRYER
Whirlpool 885458 ELECTRIC DRYER
Whirlpool 885461 ELECTRIC DRYER
Whirlpool 885462 ELECTRIC DRYER
Whirlpool 885463 ELECTRIC DRYER
Whirlpool 885464 ELECTRIC DRYER
Whirlpool 885465 ELECTRIC DRYER
Whirlpool 885468 ELECTRIC DRYER
Whirlpool 885469 ELECTRIC DRYER
  #2 (permalink)
Old 06-14-2009, 05:10 PM
Senior Expert
APP Volunteer
sidfink43 is a jewel in the rough
Default
Hi Stacey
You are going to need a multimeter and do some electrical checks.
1. Check that you have 120 volts coming to each side of the connection block.
2. If you do, unplug the machine, take off the back and check your thermal fuse and thermostats for continuity.
3. If there is no problem there, and I think there will be, check the heating element for continuity or grounding.
I think this will locate your problem. To find parts, put the numbers 110 in front of the model number you posted.
Good luck and let us know what you find out.
__________________
  #3 (permalink)
Old 06-14-2009, 07:59 PM
Senior Expert
APP Volunteer
kayakcrzy will become famous soon enough
Cool
Quote:
Originally Posted by sidfink43 View Post
Hi Stacey
Unplug the dryer. Take the back panel off, and in the back close to the bottom, there is a white part, about an inch and a half long, by a half inch wide. One screw will be holding it in place, and it will have 2 wires coming to it. Take the 2 wires off and put the terminal ends together, and put some tape around it, so it does not hit metal, and then plug it in, and see if it comes on. If it does replace the part. It is called the thermal fuse. DO NOT RUN the dryer with the part jumped out. THIS IS FOR TESTING ONLY!!!! That fuse is the only thing from your dryer burning down the house. If it does not work, check the door switch. Let me know. Tom
  #4 (permalink)
Old 06-15-2009, 08:25 AM
Junior Member
Default door switch?
Quote:
Tom,
I actually saw to try this in another thread and tried it. It did not come on.
The door switch confuses me. Since the dryer was running until I shut it off, and then wouldn't start again, would the door switch still be a possible problem?
I am going to check the switch. But I'm wondering if the timer might be the problem...
Thanks for your help. I'll let you know if I have any luck. And if I don't
  #5 (permalink)
Old 06-15-2009, 06:23 PM
Junior Member
Default
Ok. I'm an idiot. Turns out my dryer runs on 2 fuses. House fuses. Yes...I have fuses and not breakers.
Anyway, I had one blown fuse. Dryer working fine now.
Thanks anyway. I do appreciate your response.
Stacey
  #6 (permalink)
Old 06-15-2009, 07:19 PM
Senior Expert
APP Volunteer
Default
Great Stacey, Glad it turned out to be as simple as that.
That's why we generally ask that the first thing you do is check current to the machine, it is almost nevery the problem, but in the few cases when it is it makes the repair quick, easy and painless.
Thanks also for updating us.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dryer stopped mid cycle, not light on inside melissag Dryer Repair 1 11-01-2009 05:18 AM
Inside Light Stays On, Fuse Pops On Start Caleb5505 Microwave Repair 5 10-08-2009 10:20 PM
dryer only "hums" when power button is pushed, light on inside drum mastersaint Dryer Repair 3 01-08-2009 12:25 PM
Dryer light comes on but when you press start nothing happens germfix Dryer Repair 0 07-28-2008 11:28 AM
Dryer light comes on but when you press start nothing happens germfix Dishwasher Repair 0 07-28-2008 11:27 AM
