My gas dryer won't start. Checked the power-good. I hear about a Thermal fuse, I am going to check this now any other ideas. The door switch is clicking fine.
I am having trouble finding the thermal switch. Any help would be great. I cant find a match with the part shown in the catalogue. Also one of the sub la - 1053 Part Number: AP4055834 on the back of the dryer shows closed on my ohm meter is this correct. Thanks, Jason
is there any way to ell if the timer is not working properly, could this be the problem?
I think I found the termal fuse, but it has 4 wires-white, blue, tan, and yellow. The termal fuse you list on your parts list appears to only have a 2 wire hookup. How do I test this?
