| » Dryer won't heat |
| By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use. |
Model Number: nbxr453evoww Brand: Hotpoint Age: 5 - 10 years
dryer will tumble but won't heat. I've checked continuity at all thermal fuses, outlet supply, blower thermal , safety thermos and they all test good. Also tested the timer and heat switches and they appear good. So I finally was able to test the leads on the heating element. (no continuity) Bingo! Next problem is how do I get element out ? Having a hard time getting the drum out. I have removed the drum belt but am having a problem lifting it out do to catching on the front drum sliders... |
You must take the front panel off and slide the drum out the front. The back of the drum has a bearing assembly that will need to be lifted up about an inch before it can be removed. Look for screws and clips holding the front panel on. Once the drum is out, the element will be on the back bulkhead.
__________________
TechnicianBrian TechnicianBrian.com Home Appliance Repair Blog ~ Repair Advice Disclaimer ~ |
| Display Modes | |
| Dryer will run but not heat | allansc | Dryer Repair | 12 | 12-28-2007 06:10 PM |
| dryer won't heat | bullas5 | Dryer Repair | 0 | 11-23-2007 03:03 PM |
| dryer won't heat | rmzj | Dryer Repair | 0 | 11-23-2007 12:31 PM |
| dryer will not heat? | radio963 | Dryer Repair | 1 | 11-09-2007 09:02 AM |
| Estate Dryer by Whirlpool/Dryer running but no heat | tsm11238 | Dryer Repair | 1 | 11-06-2007 10:47 AM |
