Discuss
Takes tpo long to dry..
 in
Dryer Repair
I recently moved and another dryer was in use in the house. It seemed to take to long to dry
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Takes tpo long to dry..
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 12-22-2007, 11:06 PM
SLEEPING_GIANTRT SLEEPING_GIANTRT is offline
Junior Member
SLEEPING_GIANTRT is on a distinguished road
Default Takes tpo long to dry..
Brand: -brand-   Age: 1 - 5 years
It seemed to take to long to dry so we put ours in and ours is around 4 years old. It worked fine before the move.
We put it in and have the same problem.
I noticed a little bit of water coming from the vent in the wall. it has been raining recently. Could the vent be clogged? How can i get to it to fix? Is it hard to do?
Thanks in advance...
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 12-23-2007, 06:25 AM
TechnicianBrian TechnicianBrian is offline
Senior Expert
APP Volunteer
TechnicianBrian is on a distinguished road
Default
Verify the vent is not restricted and the connection hose from the dryer to the wall connection is not folded over itself behind the dryer. As long as the dryer is heating, the long dry times are from a vent restriction. You probably notice the clothes are very hot, but remain damp to the touch.
__________________
TechnicianBrian
TechnicianBrian.com
Home Appliance Repair Blog
~ Repair Advice Disclaimer ~
  #3 (permalink)
Old 12-23-2007, 12:18 PM
Junior Member
Default thanks...
Ya there was some amount of lint in the vent. Not enough to make me think it was blocked tho. The vent goes nearly straight up to the roof i believe. Could there be a blockage up higher? I felt wrist length in and nothing was there except some at the entrance and it was wet.
  #4 (permalink)
Old 12-23-2007, 12:25 PM
abbie abbie is offline
Senior Expert
APP Volunteer
abbie is on a distinguished road
Default
Try the next dryer load with the vent off the back.Just crack a window open to get rid of the moisture inside the house.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
takes to long to dry jstyles Dryer Repair 1 12-17-2007 07:25 PM
Dryer takes to long to dry Julito Dryer Repair 1 12-05-2007 12:10 PM
Dryer Takes way to long to dry confused Dryer Repair 4 08-12-2007 08:38 PM
Takes too long to dry:Duet Scottpiggs Dryer Repair 4 08-10-2007 12:49 PM
Dryer Takes Very Long to Dry Clothes jdavis Dryer Repair 2 07-25-2007 04:00 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
