Discuss
whirlpool dryer not drying
 in
Dryer Repair
dryer not drying checked breakers and is lent free and dryer is still turning would like to know where to
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » whirlpool dryer not drying
  #1 (permalink)
Old 06-10-2009, 09:16 AM
slushdog69 slushdog69 is offline
Junior Member
slushdog69 is on a distinguished road
Default whirlpool dryer not drying
Brand: Whirlpool   Age: 1 - 5 years
dryer not drying checked breakers and is lent free and dryer is still turning would like to know where to start need help thank you .
  #2 (permalink)
Old 06-12-2009, 10:13 AM
sidfink43 sidfink43 is offline
Senior Expert
APP Volunteer
sidfink43 is on a distinguished road
Default
You will need an ohm meter to do some testing.
1. Check to make certain that you have 120 to each side of the connection block.
Then unplug the machine.
2. Check your fuses and thermostats, particularly the thermal fuse.
3. If you do not find the problem, check your heating element for resistenance, and make certain it is not grounded.
It is highly likely you will find the problem. Good luck and Let us know how it turns out.
__________________
  #3 (permalink)
Old 06-15-2009, 06:53 AM
frostywashdry frostywashdry is offline
Member
frostywashdry is on a distinguished road
Default
Quote:
possibly the heat coil( not sure what they call it) , or sensor.
  #4 (permalink)
Old 06-15-2009, 07:29 AM
Senior Expert
APP Volunteer
Default
Yes, if this is a gas dryer (we did not have the model number) look at some of the posts on heating problems with gas dryers to check out that part of your machine (I do not work on gas appliances so I can only point you to the posts)
Hope you find the problem and let us know what you find out.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool Dryer Starts Drying and then Stops rlager Dryer Repair 1 08-17-2009 05:52 PM
Whirlpool Electric Dryer not heating/drying GeminiDreams Dryer Repair 3 06-16-2009 03:52 PM
whirlpool dryer heating but not drying ksimager Dryer Repair 1 06-04-2009 01:56 AM
whirlpool dryer not drying loq24 Dryer Repair 2 12-03-2008 05:10 AM
Whirlpool Dryer not drying good hmfary1 Dryer Repair 1 02-12-2008 07:58 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
