| » Drier stops when you release start switch |
Model Number: dbxr463eb1ww Brand: GE Age: 1 - 5 years
Drier stops when you release the start switch. It will run through complete cycle if you hold the start switch on.
Replacement parts for GE DBXR463EB1WW | AppliancePartsPros.com Note: getting tech info on GE's off the net is difficult to say the least. Do you have the wiring diagram? If not open up the control console and take a look, they like to store the diagrams in there. The diagram will show you what closes to hold the unit on when the start switch is released. Often this is one of the centrifugal switches on the motor but there are other methods used. When you hold the start switch closed do you get heat? If not then odds are high that the mechanism in the motor which closes the centrifugal switches is not working. One switch removes the motor's start winding from the circuit and may hold the unit on when the start is released. The other, switches on the heating element. Here is a good link with basic info. Check out the GE section, there are some typical wiring diagrams available here http://www.applianceaid.com/dryers.html
__________________
when instart the dryer it goes and then it stops after trying to start it again it want we have to let it sit a while before it starts again
deeboy31
Please start your own thread in this forum using POST NEW TOPIC, be sure to include the Make and Model. Your problem is different from jhall8891's and being part of their thread will just confuse things Thank you denman
__________________
| Display Modes | |
| GE Gas dryer stops running when start switch is released | gevscott | Dryer Repair | 0 | 01-05-2010 02:54 PM |
| Magic Chef drier not getting power, won't start. | Chris72 | Dryer Repair | 2 | 10-21-2009 01:35 PM |
| dryer start but stops when I release start button | vchss360 | Dryer Repair | 7 | 10-20-2009 03:46 AM |
| my electric drier will not start | Adriano | Dryer Repair | 1 | 07-07-2009 04:48 PM |
| Drier drum belt how to start in the back or front??? | White westinghouse | Dryer Repair | 2 | 12-05-2007 02:37 PM |
