Discuss
No Heat dryer
 in
Dryer Repair
I have no heat . I want to chexk the fuse but I cant seem to get the bottom cover off.
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » No Heat dryer
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 12-21-2007, 10:59 AM
chaionsaw chaionsaw is offline
Junior Member
chaionsaw is on a distinguished road
Default No Heat dryer
Model Number: 76912693-76912   Brand: Kenmore   Age: 1 - 5 years
I have no heat . I want to chexk the fuse but I cant seem to get the bottom cover off. It seems like it is springed to some thing. No clicking noise at all like the heat is not even starting..
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 12-21-2007, 01:14 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
The first thing I would check is the thermal fuse (#59 on the bulkhead parts break down diagram).
In order to remove the bottom panel you have to push in (using a putty knife) the retainer (#46 on the cabinet break down diagram) on each side on top of the bottom panel.
Replace the thermal fuse if it's open.
According to the manufacturer instructions, if the thermal fuse is open, the cycling thermostat has to be replaced either (#42 on the bulkhead parts break down diagram).
If there is nothing wrong with the thermal fuse, then check the igniter (#4 on the burner break down diagram).
- The part number for the thermal fuse is AP3133489
- The part number for the cycling thermostat is AP3131939
- The part number for the igniter AP3094138
Good luck.
__________________
Professional appliance repair services in Orange County, California.
  #3 (permalink)
Old 12-22-2007, 02:20 PM
Junior Member
Default
Thank You that is what it was fuse.. thank you very much and have a great christmas...
  #4 (permalink)
Old 12-22-2007, 02:37 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
I'm glad you were able to fix it.
Merry Christmas and Happy New year!
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
No Dryer Heat Warren Dryer Repair 19 04-28-2008 08:24 PM
Dryer won't heat maillady Dryer Repair 3 11-20-2007 06:37 PM
Estate Dryer by Whirlpool/Dryer running but no heat tsm11238 Dryer Repair 1 11-06-2007 10:47 AM
My Dryer only has low heat rmoss@footprintscarolina. Dryer Repair 3 10-18-2007 03:09 AM
Dryer won't heat!!!! DSunga Dryer Repair 3 09-30-2007 01:03 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
