Discuss
Estate(Whirlpool) Electric Dryer not heating
 in
Dryer Repair
Hello. Reading thru this forum and I am having the same problem it appears. My Roper dryers heat will come
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Estate(Whirlpool) Electric Dryer not heating
  #11 (permalink)
Old 12-09-2012, 01:21 PM
Junior Member
keitort is on a distinguished road
Default Dryer heat cycling off
Hello. Reading thru this forum and I am having the same problem it appears. My Roper dryers heat will come on but just for a minute or two. Everything else appears to be working. i.e. timer, motor,etc. I have checked all the switches (high limit, cycling thermostat)with a ohm meter and all have continuity. Heating element checks ok and does not read that it is grounded out. Checked timer by testing black-blue connections. All is good. Vent is free of lint from unit all the way to outside. Driving me crazy.
  #12 (permalink)
Old 12-10-2012, 12:07 PM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
keitort
Start a new thread using "POST NEW TOPIC"
Be sure to include the make and model number.
Adding to this post about a different model will just confuse things.
Also more detail on the problem.
Does it do this on full heat only or also on low heat?
Does the heat come back on later or does it shut off and stay off?
etc.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Estate by Whirlpool Electric Dryer barbanns Dryer Repair 1 08-20-2011 06:16 AM
Whirlpool Estate Electric Dryer Jefnir Dryer Repair 3 06-17-2011 02:22 AM
Whirlpool Estate Dryer Stopped Heating kimyoung Dryer Repair 1 05-17-2011 04:45 AM
whirlpool estate electric dryer takes two or three times to dry huckfinn979 Dryer Repair 2 08-24-2010 08:00 AM
Estate whirlpool electric dryer CAYCE Dryer Repair 1 07-26-2009 05:17 PM
