Roper gas dryer won't heat up.It tumbles , but no heat.Won't shut off in Auto Sense Dry (High Heat) , but will shut off with timed dry , but no heat. It also makes a humming for about 1 minute , then it stops afetr a few minutes , humming , 1 minute stops , etc.I have replaced the fuse-thrml (WPL 3392519) and thrmst-fix (WPL 3387134) that was suggested to another person on this site for this problem.I also replaced thermal cut-off (fuse) kit-icludes high limit thermostat.I hope you can offer some advice. Thanks , Ed
