Discuss
Dryer does not get hot
 in
Dryer Repair
Dryer stoped getting hot or warm and does not dry the clothes. It is cold inside the dryer. I have
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Dryer does not get hot
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 12-20-2007, 08:50 AM
mustvid mustvid is offline
Junior Member
mustvid is on a distinguished road
Default Dryer does not get hot
Model Number: TEDL660W   Brand: Estate   Age: 5 - 10 years
Dryer stoped getting hot or warm and does not dry the clothes. It is cold inside the dryer. I have reset the breaker (it was not tripped) and same problem exists. I have replaced the heating element before. Is it the element? Prior to this it was taking a while to dry clothes although after a few cycles the clothes were hot when taken out.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 12-20-2007, 05:33 PM
misterfixall misterfixall is offline
Senior Expert
APP Volunteer
misterfixall is on a distinguished road
Default
if you have a multimeter check for continuity on heater ,thermostats ,thermalfuse .may even be timer .use wiring diagram for timer to see which contacts close to heatercircuit ,turn timer todry cycle ,like minutes cycle
  #3 (permalink)
Old 12-25-2007, 06:54 PM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
A major cause of failure to heat is a blocked vent which will shortly destroy the heating element, please check.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
