Discuss
any tricks to popping panel clips with putty knife?
 in
Dryer Repair
Is there a trick to disengaging the rentention clips that hold the front lower panel in place on a dryer?
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » any tricks to popping panel clips with putty knife?
  #1 (permalink)
Old 06-03-2009, 01:38 PM
Junior Member
sparky110 is on a distinguished road
Default any tricks to popping panel clips with putty knife?
Brand: Whirlpool   Age: 1 - 5 years
Is there a trick to disengaging the rentention clips that hold the front lower panel in place on a dryer? I'm using a putty knife but nothing happens.
thankyou!
Ads By Google
  #2 (permalink)
Old 06-03-2009, 06:21 PM
Senior Member
applianceman is on a distinguished road
Default
On most Whirlpool dryers you have to pull the filter out top of the dryer and remove the screws under it for the top to lift up. Once the top is up the front is held on by screws. Hope this helps! Clothes Dryer Repair Guide
  #3 (permalink)
Old 06-03-2009, 06:38 PM
Junior Member
Default
It's the screws not clips that hold the panel on - the mfg. info was incorrect. thanks for straighting this out!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
tricks triks Washer Repair 1 12-21-2009 03:13 AM
Front Panel clips (dryer) rfjjulie Dryer Repair 1 01-25-2009 06:02 AM
