Discuss
Cycle timer not cycling
 in
Dryer Repair
The timer will not time in the automatic timing cycle. I replaced the timer and the problem still is there.
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Cycle timer not cycling
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 12-19-2007, 10:02 AM
dbelisle dbelisle is offline
Junior Member
dbelisle is on a distinguished road
Post Cycle timer not cycling
Model Number: NVLR333EV0WW   Brand: Hotpoint   Age: 5 - 10 years
The timer will not time in the automatic timing cycle. I replaced the timer and the problem still is there. I'm not sure if the resistor could be bad or if one of the thermostats is bad.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 12-19-2007, 04:09 PM
abbie abbie is offline
Senior Expert
APP Volunteer
abbie is on a distinguished road
Default
I would say you have part of the heating element not working. if you have an amp meter this would be easy to check.go to the back where the plug enters the dryer, there may be a cover you can open. Place amp meter over the heavy[ i think] black or orange wire While dryer is going this should show at least 23 amps if heater is ok. If only one side of the element is working it will only show about 15 or 16 amps.The heating element should be good before you can have the automatic cycle working.If element has an open coil it will NOTwork.
__________________
  #3 (permalink)
Old 12-26-2007, 02:59 PM
Junior Member
Default
Abbie, this was the problem, and once I replaced the heating coil the timer started working. thank you for your input.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Oven cycling on and off. LeeTBaker Oven Repair (including Ranges and Cooktops) 0 12-01-2007 07:33 AM
Dishwasher skips the wash cycle and stops at the rinse cycle jasporo Dishwasher Repair 1 11-16-2007 05:12 PM
Fridge seems to be cycling bassclef Refrigerator & Freezer Repair 0 11-11-2007 09:06 AM
Starts cycle, gets "stuck" with h2o in bottom, timer is still heard-lights on too. julialovesjohn Dishwasher Repair 1 10-03-2007 07:16 PM
Timer again??? 4dugnlee Washer Repair 8 08-17-2007 06:45 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
