Here are your parts.
Replacement parts for WHIRLPOOL REX4635EQ2 ELECTRIC DRYER | AppliancePartsPros.comSee the attachment for a wiring diagram. I could not find one for an EQ2 so the diagram is for an EQ0 but odds are good that yours is the same.
Start by checking the power, the heating coil requires the full 240 volts.
Try flipping the breaker off/on slowly a couple times.
Sometimes you can loose half the line without actually tripping the breaker.
If this does nothing, check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
[COLOR="Red"]
Be careful as 240 volts is lethal !!![/COLOR]
Next check the heating coil, the hi-limit thermostat and the thermal cut-off.
Heating coil should be 8 to 12 ohms. Both the other parts should be 0 ohms.
If the thermal cut-off is blown get back to us before replacing it as there are other things to check before replacing it.
4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
