Discuss
Rebuilding Maytag LDE 7500: felt drum seals
 in
Dryer Repair
Really great example of describing
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Rebuilding Maytag LDE 7500: felt drum seals
  #11 (permalink)
Old 08-06-2015, 01:31 AM
Junior Member
Andy76 is on a distinguished road
Default
  #12 (permalink)
Old 10-04-2015, 12:33 PM
Junior Member
Charlottesville is on a distinguished road
Default
I found Parts Select to be excellent for all parts and they answer their phone's within 2-3 rings!
  #13 (permalink)
Old 01-29-2018, 06:57 AM
Senior Member
thorning is on a distinguished road
Default
I just ran across the excellent writeup and pictures of the teardown, repair, and reassembly of the Maytag dryer. You did a very good job on the pictures. I have done a few of these and I would add a couple of notes. The drum can be reversed as it is made to allow it to be installed either way. I also use Loctite on the baffle screws to prevent them from coming loose. Also look at the blower fan to see if there are cracks at the hub . This is a common problem with this design and they sometimes break off causing the fan to rattle around loose on the shaft. They are fairly low cost and it would be a good idea to replace it with a new one. I also use an air compressor and blow out the dirt instead of a vacuum.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
drum felt seal lucky0323 Dryer Repair 8 10-28-2011 12:17 PM
Drum Slide & Felt pad regmike Dryer Repair 0 08-23-2011 10:59 AM
Replacing Drum Glides And Felt loria Dryer Repair 1 03-14-2010 08:01 AM
replacing drum felt CARS Dryer Repair 1 02-24-2010 07:51 PM
rear drum felt seal allthewrights Dryer Repair 1 08-01-2009 05:14 PM
