| » How do I remove the Dryer Drum |
Model Number: 417.91702000 Brand: Kenmore Age: 5 - 10 years
I need toremove the Dryer Drum and was told to remove door lift drum and pull, but having no luck. Any suggestions?
you will have two screws where the lint screen is ,remove them , then with a slot screw driver at front insert at either corner and pry up , you will see two screws at left +right securin g front panel .remove them then pull panel towards you +up to detach from bottom clips,put panel along side of dryer.do not detach wires. remove belt at bottom back at right from tension pulley .remove drum
__________________
| Display Modes | |
| how do I remove the metal cabnet and repace a new drum belt | Tinas7 | Dryer Repair | 2 | 01-03-2008 05:04 PM |
| dryer drum | wally gator | Dryer Repair | 0 | 11-22-2007 10:16 AM |
| dryer drum | wally gator | Dryer Repair | 0 | 11-22-2007 10:13 AM |
| How to remove control panel on GEW9868K dryer | Speadracer | Dryer Repair | 4 | 10-29-2007 03:32 PM |
| how do I: remove rear drum bearing frigid front load? | treefrog | Washer Repair | 0 | 08-19-2007 02:12 PM |
