Dryer not drying properly, opened door and pressed switch to run and watch heating element, heated up for less than 30 seconds and turned off, must be cycling because laundry dries somewhat but takes forever to dry completely. Checked continuity on all three (3) thermostats-all good Checked heating element-ohm's within limits Blower operating and vents cleaned/clear no obstructions Checked continuity on timer element wiring-good Time to buy a new dryer? Do not know what else it can be.
