| » Converting from a 3-prong cord to a 4-prong dryer cord |
Model Number: 800 Brand: Kenmore Age: 1 - 5 years
I have a 3-prong dryer cord and I am trying to switch to a 4-prong. There is a white cord coming from inside the dryer attached to the ground screw. Do I leave that cord attached and also attach my green cord to the same screw or do I take the white cord off and just put the green one on?
It would be best to get the full model number and then find a install sheet on the web, probably the Sears/Kenmore site. It should tell you how to change the line cord.
Kenmore numbers are 3 digits, a period and then 8 digits I can give you some basic info. On a 3 wire machine ground and Neutral are the same. On a 4 wire machine ground is separate from the Neutral. It is true earth ground. On a 3 wire there is usually a jumper wire that runs from the terminal strip Neutral/white (usually the center connector) to the machine frame. When changing to a 4 wire this jumper is removed. The line cord Neutral/white is connected to the terminal strip center connector (usually). The line cord Ground/green is then connected to the machine frame.
__________________
| Display Modes | |
| changing 3 prong dryer cord to 4 prong | russb | Dryer Repair | 1 | 08-12-2011 11:14 AM |
| Changing 4 prong dryer cord to 3 prong | BradleyT | Dryer Repair | 2 | 08-10-2011 03:43 PM |
| Washer machine power cord 3 prong missing ground prong REplace? Is it ok? | maddy | Washer Repair | 1 | 06-17-2011 04:36 PM |
| installing a new 4 prong cord to 3 prong dryer | nmcfay1226 | Dryer Repair | 9 | 02-09-2010 03:23 PM |
| Converting from 3 to 4-prong electrical cord | HuskerTodd | Dryer Repair | 0 | 12-29-2009 05:34 AM |
