| » Dryer Won't Start After Initial Cycle |
| By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use. |
Model Number: LG8123WM Brand: Amana Age: More than 10 years
I have an Amana LG8123WM gas dryer that will not start after the initial cycle. The dryer will run for one load but when I try to restart it for the second load I hear a buzzing sound. I replaced the timer and still have the same problem. Could the problem be the thermostat?
more than likely the buzzing was coming from the motor ... if you have a helper , have someone depress the start button on the control panel and you can put your hand in the drum and depress the door switch and then push the baffle of the drum ( i think it is clockwise ), if the motor starts, it was a bad motor or if it seems very difficult to turn the drum, the motor is bad ..
__________________
regards jim |
| Display Modes | |
| No flame after initial start | jrileysr | Dryer Repair | 1 | 12-08-2007 06:38 PM |
| Dryer stopped mid drying cycle and won't start again | scsimpson | Dryer Repair | 2 | 11-25-2007 06:44 PM |
| washer want start the spin cycle without help? | elizabeth | Washer Repair | 0 | 11-23-2007 06:41 PM |
| No water during start-up cycle | Avogel | Dishwasher Repair | 1 | 10-03-2007 09:47 PM |
| maytag gas dryer will not heat after initial burn | Agustin | Dryer Repair | 1 | 08-28-2007 09:48 AM |
